Sattlite TV experts needed |
Butch(OH)
Topic: Sattlite TV experts neededPosted: 21 May 2018 at 8:10am |
Working on a new patio and got into the satellite TV cable and cut it. Wife calls dish net and they say two weeks to get here and fix,, grr, doesn't bother me but makes wife hard to get along with. So I go to town and get a couple cooax connectors, and installed them per instructions so she could have TV until they get here to install new cable but the TV still says no signal? Cable isn't cut anywhere else and I am certain that I installed the ends correctly, I cut them off an did it twice. We rebooted the system several times to no avail, anyone with knowledge of these things know what is going on? Thanks!! Would help life at home for 14 days
fixer1958
Posted: 21 May 2018 at 9:38am |
I went through that before. One of the ground strands (wire wrapped sheathing under the outer cover) was touching the copper signal wire when putting the connector on. I completely understand the implications of not having the creature comforts the 'other one' needs to survive. That's all I have to offer.
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Posted: 21 May 2018 at 9:55am |
prob what fixer said.
So how far is it from the dish to the plug in at the house? if close like mine you could just get a roll of ready made coax and throw it above ground for an interim |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 21 May 2018 at 10:52am |
is there a reset on splitter or anywhere?
CaseyCreek
Posted: 21 May 2018 at 4:39pm |
I second the idea of buying a new cable and running it from your receiver out to the grounding bar. Lots of people don't realize that every connection causes signal loss. And as someone mentioned earlier, not all coax splices are successful. How long of a run are you needing? Amazon is listing a 50-foot run quad-shielded with terminations already applied shipped to your door for $16 (if you are an Amazon Prime member). https://www.amazon.com/Satellite-Broadband-PHAT-SATELLITE-INTL/dp/B01GBVYAZC/ref=pd_lpo_vtph_23_bs_tr_t_1?_encoding=UTF8&psc=1&refRID=W1620XMW06M5GP7TTBTX |
D17 Series III,D17 Series IV, 185
weiner
Joined: 19 May 2012 Location: Cadillac, Mi. Points: 4304 |
Posted: 21 May 2018 at 5:03pm |
Be sure and demand 2 weeks off your next cable bill.
Real heros wear dogtags, not capes.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25242 |
Posted: 21 May 2018 at 5:49pm |
I'll make the assumption that there's a power supply (aka Wallwart) feeding power to the dish, if so, see if the 'power on LED' is on. If not, disconnect the coax to it, pull wallwart out of recptacle, count 10 steamboats, plug wallwart into receptacle. does the LED come on ? If so...reconnect coax. does the LED stay on " If so...should have TV.
If the LED goes off, cable is shorted,killng wallwart....find short,repair, go through all this again.... Jay |
john(MI)
Posted: 21 May 2018 at 6:46pm |
On mine there is a section in the menu for maintenance. if I remember correctly there is a choice to test the switch. run that test. if there is a selection for signal check to see what you are getting from each lnb or whatever they call them nowadays. Too many connections can cause problems can cause signal loss but one should not be that extreme. if you go with the new cable route, the choice cable is RG6 if I'm not mistaken. There are a couple different impedance cable choices. I believe you need 75 ohm cable. It's been a while since I messed with this stuff so I may be incorrect on some of it. also if there's a radio shack in the neighborhood they will have the cable. if not, you can probably order from Walmart to pick to in the store and get it quicker then Ebay or amazon. Another option is to pick up an on air antenna for the local channels to appease her during the week. most big box have them in the store.
shameless dude
Posted: 21 May 2018 at 11:06pm |
yep...yer gonna pay for new anyways!
Walker
Posted: 22 May 2018 at 12:09am |
I want to know why when there is one cloud in the universe it sits between my dish and the satellite its aimed at.
Brian Jasper co. Ia
Posted: 24 May 2018 at 9:10am |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Posted: 24 May 2018 at 9:24am |
Cuz Karma. That's why.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4070 |
Posted: 24 May 2018 at 9:25am |
good time to get rid of the satalite dish and go back to an antanna, we did a few years ago and probly wont go back agian. all thow are antanna i mounted were the dish was and hooked in to the same cable so it sounds like a repair is still in order
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 22 Jul 2020 at 2:47pm |
Wanting 2 weeks off the bill?
Now that’s funny!! I don’t care who you are Edited by Lars(wi) - 22 Jul 2020 at 2:49pm |
Dakota Dave
Posted: 22 Jul 2020 at 4:42pm |
The lru is powered by the reciever. Your reviever should be pushing power to the dish trough thur the coax. The signal then comes back to a blocking diode at the reciver. Check for power at the coax. If dosent have power thelru wont send any signal back. Youhave to have a good connection on both vanle ends and the spli you added. You probaly dont. Ive bent the conductor to get signal where it goes into the splice about 50 % of the ones i got from walmart were defective.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6124 |
Posted: 22 Jul 2020 at 8:47pm |
The original post was MAY of 2018 guys... this problem has long-since gone...
