safety lock on raised hyd. cyl. |
Randaleky
Joined: 17 Aug 2011 Location: belfry, ky. Points: 427 |
Topic: safety lock on raised hyd. cyl.Posted: 23 Feb 2018 at 7:52pm |
I am about to pull the front grill and frame of track loader in order to remove the radiator for repair or replace. I was just wondering what system others have used to block the loader bucket and frame in raised position to allow safe work on removal. thanks
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55262 |
Posted: 23 Feb 2018 at 8:34pm |
Piece of angle iron, cut to length, and hose clamped over the cyl rod should do the trick...
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25239 |
Posted: 23 Feb 2018 at 8:52pm |
I welded 2 pcs of 2by2 angle into a U channel. Then welded couple of washers 1/2 way on one end. U-channel slides over the ram shaft, and a PTO clip goes through the holes of the washers to safely secure U-channel from falling off.
I use these to keep the bucket from lowering itself to the ground. |
Randaleky
Posted: 23 Feb 2018 at 9:10pm |
thanks guys. I thought about piece of round pipe with section cut out to slide over rod and u bolt to secure it, all great ideas.
HD6GTOM
Posted: 24 Feb 2018 at 12:14am |
If it has a good heavy brush cab like my HD6G's did I would raise it all the way then use 2 heavy chains to bind it up. Please Notice I said 2 chains. My bucket was very heavy. Always worked for me.
Edited by HD6GTOM - 24 Feb 2018 at 12:14am |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35650 |
Posted: 24 Feb 2018 at 5:26am |
On my 7G the bucket was too heavy where I was actually seeing distortion on home made cylinder supports. I chose to unpin the bucket as well just supporting the arms.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42263 |
Posted: 24 Feb 2018 at 8:58am |
If you use the angle iron or other stop over the cilinder rod - be sure the packing gland on cylinder is not part of support system - a adjustable packing gland like on HD5B will distort or crush packing material if force is put against it .
I have used 4x4 timbers under raised bucket as well as chanel iron clamped over rod . Seems on dump trucks any time a box is raised 2 types of stops are used under box to prevent lowering . Was a nice feature on my New Holland 785 Skid Loader - they had a built in boom safety stop behind seat to prevent boom lowering to pinch or kill zone |
Randaleky
Posted: 24 Feb 2018 at 11:36am |
I believe I will chain lift to the ROP canopy and place the backhoe dig boom under the boom also. Plus angle iron for fail safe also. better safe than dead.
Randaleky
Posted: 24 Feb 2018 at 11:38am |
Thanks to all for the good response. This site is certainly the place to ask questions.
jerbob
Posted: 24 Feb 2018 at 5:00pm |
The folks on this forum are the best.
Randaleky
Posted: 27 Feb 2018 at 11:41pm |
Well I chained loader across canopy, set 4 x 4 post under raised frame, and put backhoe boom under loader also. I think that will work ok.
