SAE 250 Gear Oil |
Post Reply |
TimCNY
Orange Level Joined: 15 Apr 2014 Location: Upstate NY Points: 1551 |
Posted: 25 Jun 2019 at 9:27am |
For steering, WD45 wide front. Not an easy item to find and pretty expensive when it is found. Nothing local to me but I did find Lubriplate SPO-288 available for $65/gallon shipped. I know it takes just a quart or so, but this tractor's going to be on a tight maintenance regimen from now on; better the prevention than the cure. Any recommendations? Lubriplate OK? I'd rather stick with dino instead of synthetic, the synthetic is just crazy more expensive from what I've been able to find.
Thanks! - Tim |
TimCNY
Also the Lubriplate APG-250, not sure if a better choice. In line with the SPO-288 price-wise.
Orange Level Access Joined: 12 Sep 2009 Points: 19473 |
Why not just corn head gearbox grease ?? Readily available one tube at a time and much cheaper than you are thinking.
JohnCO
Orange Level Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
What SAE weight is the corn head grease?
Allis Express participant |
TimCNY
Well, Doc, I figure because I didn't know that corn head grease was a suitable substitute. If you say so, that's what I'll get! Thank you.
TimCNY
John, didn't see your post when I replied. I haven't a clue, either. Just on my way out right now to get a tube or two on my way back to the farm, maybe I'll hold off. But I figure if DrAllis says good to go, who am I to say otherwise? I'll get the corn head grease and call it good until and unless there's a reason to replace it. But for now I'm calling it good enough.
DougS
Orange Level Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
This would be NGLI 00 or 000 grease. It isn't the same as oil. Oil is supposed to flow. Grease isn't |
Don(MO)
Orange Level Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Like Doc when I rebuild front ends they all get corn head grease, I pack the bearings and as they are being built then just fill the housing up to the fill hole, drive it around in first gear turning hard left & right and refill back up again. You might try removing the grease fitting off the end of gun it might pump in faster I have not tried doing that but might help.
TimCNY
OK. That's corn head grease for me. Hard to say that or read it and not get hungry for a stack of johnnycakes lol!
Edited by TimCNY - 25 Jun 2019 at 10:34am |
jorstad brothers
Orange Level Joined: 10 Jun 2010 Location: tioga nd Points: 473 |
Pack with grease than top off with Lucas hub oil.
remember plunder than burn
Bill_MN
Orange Level Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1463 |
I've seen several times where guys mixed grease and oil in the front end to make something close to 250 wt, less scientific that way but if it doesn't leak out lubrication is lubrication.
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3893 |
I put corn head grease in all mine it's a little thicker than 250w but still will flow around the gears. When we had problem gear boxes on aircraft we mixed grease and hyd fluid 50/50 and heated til you could stir. It was a leagle fix for leaky gear boxes on air planes till it went to the next 5 year depot Maintance.
TimCNY
Corn head grease is in. But I think it's a lot easier to tell how much is in there when it flows a bit. I figure there's about 1-1/2 tubes of grease. Turned left-right stop-to-stop a lot in-between fillings. Topping it off with Lucas hub oil doesn't sound like a bad idea to me, might try that after a few days of working her.
Thanks, all! - Tim |
Post Reply | |
