SAE 20 Oil?
Steve Jelf, So KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Jelf, So KS Quote  Post ReplyReply Direct Link To This Post Topic: SAE 20 Oil?
    Posted: 03 May 2020 at 1:40pm
The B & C service manual calls for SAE 20 oil in the transmission. No local store carries it. The only actual SAE 20 I found online with a Google search is out of stock. All other listings are for multigrade oils. SAE 20 and 5W-20 are not the same thing. Any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 1:56pm
Theres plenty of 30 w. out there, im  sure it would be fine hwy duty 30 ,,
Edited by DougG - 03 May 2020 at 1:57pm
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 3:07pm
The only place I have found SAE 20 has been at farm stores in generic bottles. Not rated for engine use, but seems to work good in the WD's hydraulics.
200 10and20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 10and20 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 3:24pm
Originally posted by Steve Jelf, So KS Steve Jelf, So KS wrote:
<font size="4" face="Times New Roman, Times, serif">The B & C service manual calls for SAE 20 oil in the transmission.<font size="4" face="Times New Roman, Times, serif"> No local store carries it. The only actual SAE 20 I found online with a Google search is out of stock. All other listings are for multigrade oils. SAE 20 and 5W-20 are not the same thing. Any suggestions?
Buy AW 68 hydraulic oil that is 20w
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 4:40pm
Don't even bother use utf. Or uthf. Just go to your local store and buy what ever says tractor hydraulic fluid. Any thing is better than SAE 20 ND. If you put 30 wt in you'll regret it as soon as it gets a little cold.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 5:01pm
Dave would you buy the 303 yellow bucket?
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 6:13pm
Back in my day SAE 20 NON DETERGENT oil was the right thing to use in the Hyd for the B-C-CA.  However, this is the 21st century and there is much better oil out there  Some of the information above is correct also I hear of hydratran oil which is highly recommended too.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 6:25pm
Generally, modern day trans /hydraulic fluid is a 10W-30 and if good enough for 600 HP tractors, sure ought to be plenty good enough for a model B-C-CA tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 6:28pm
I've been using Walmart 'Universal Tractor Fluid ' for 15+ years,and whether I use or abuse the D-14s they still run fine. SAE30 for the engine, UTF for everything else. Makes life simpler.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 6:32pm
I personally buy whatever the local hardware store has. It's usual a black bucket says universial tractor hydraulic fluid. 303 is one of the spec numbers it claims to meet. Of that's what you get localy the use it. You B only holds 10 quarts so a 2.5 gallon jug will completely fill your C after draining it.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 8:55pm
I've been told the air compressor oil at the big box stores is 20 non detergent.
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 8:57pm
Long time no see Steve. Good to know you're still around.
