Rust prevention in fuel tank? |
Leon B MO ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2191 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Sep 2016 at 8:13am |
I have a couple of antique tractors that only come out of the shed once a year. The UC hasn't given me problems but the tank on my U is a problem every time it sits for a while. Couple of weeks ago I flushed it out the best I could and got about tablespoon of rust out of it but last night the sediment bowl choked up again. I'm going to put a screen in the bowl inlet but that really doesn't fix the rust problem.
Question is should these tractors be stored with the fuel tank completely full? If so, by the time I would get back to it, the gas would be bad. Hate to throw $50 bucks worth of gas away every year. Also don't want to ruin the paint buy taking of to work on it. I don't know if a tank liner would even stick to it. What do you guys do for storing your oldies? Leon B ok |
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8456 |
I'd like to know too.
I've always just heard to keep the tank full and add some Sta-Bil.
Bob-Maine ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central Maine Points: 922 |
Leon, Good question. I will tell what I do and others will chime in (and maybe disagree with me). My tractors have the same problem. When I restore a tractor, I clean the gas tank. I try to remove any corrosion by shaking the tank with some loose items in the tank (steel hex nuts). I will be doing a tank soon and hope to fasten it to the barrel of a small concrete mixer and let 'er spin for a while. After cleaning out the loose rust and flushing out the tank, I coat it with Red Kote liquid tank liner. Takes a quart or two, depending on the tank size. When the liner dries, you should be good to go. When I store a tractor, I siphon out all the gas I can get, let the rest sit and put in fresh gas the next time I start it. This has always worked for me. Hope this helps.
Bob@allisdowneast |
I used to think I was indecisive, but now I'm not sure.
I should have said I also add Stabil and run the tractor before I siphon out the gas. What comes out goes in the lawn tractor (unless it is real old). Bob
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Even a full tank, with ethanol they can still rust as ethanol attracts water. My brother even stored some parts in a pail of diesel fuel and they still rusted as the biofuel in the diesel attracted water. I've witnessed it first hand when he pulled the parts out. Just look at the fuel tank neck on your diesel and you will probably see rust. Especially if your state or your fuel supplier uses a lot of biofuel in the blend.
Wink I am a Russian Bot |
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 10966 |
The only true way is to get air plane gasoline. No ethanol used there.
TimNearFortWorth ![]() Orange Level ![]() ![]() Joined: 12 Dec 2009 Points: 2014 |
X 2 on the Avgas and I will not use StaBil again as it gums stuff up over time. A can of Seafoam in about 5-7 gallons of fuel under use occasionally is also good for keeping the old gals clean. Currently messing with a D15 that sat behind some stored round bales under an awning for 10 months and it bit me as I left it only 1/4 full. The initial gas drained out stunk to high heaven and a tray type pan with about 3/4" turned to a gummy type consistency within 48 hrs. of sitting exposed to ambient. Can see what looks like rust trying to form on the inner walls of tank so bunged her up and filled nearly full with diesel and one gallon of Marvel Mystery Oil. Circulate same with an air hose every few days and about ready to drain, rinse with gas a couple of times and see what it looks like. Worth mentioning the carb was caught in time as she runs smooth after some heavy does of Seafoam put through her using a portable gas tank so I guess I got lucky . . . .
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7514 |
Get the tank cleaned out very well. Lots of small garages will soak them with myriatic acid. Once clean and dry, get the inside coated. There are several products on the market. I had the tank on my WD45 coated earlier this year due to rust - as good as new! Fill with fresh gas right from a gas station, NOT the gas barrel at the farm!
If the gas breaks down before the tank is empty, you are not using it enough! These old tractors need exercise! Hop on and run them! |
Dans 7080 ![]() Orange Level ![]() Joined: 05 Feb 2010 Points: 1146 |
I'll second Bob on the red kote. Had my 45 done over 15 years ago and have had absolutely no issues with it. The local radiator shop did it.
Edited by Dans 7080 - 16 Sep 2016 at 6:21am |
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Dan73 ![]() Orange Level ![]() ![]() Joined: 04 Jun 2015 Location: United States Points: 6054 |
3x on that I had mine done about 7 years ago on my d17. My uncle ran that tractor with rust problems for years big headache solved and money well spent at the rad shop if you ask me. The one thing I would add is shut off the fuel bowl and let the tractor burn the fuel out of the carb when you put it up. I do that in the fall and come spring my d17 starts right up without trouble. I filled the tank in the fall and didn't have fuel trouble come spring. But the year before I left fuel in the carb and had all kinds of jelly in the carb. Letting it drain the carb seems to work the best for me. ![]() Edited by Dan73 - 16 Sep 2016 at 3:18am |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24731 |
've wondered if 'Black Baron Epoxy' found in the RC hobby shops would be
better than Red Kote ? Seems to me that epoxy must be really tough
considereing how powerful RC plane gas is but epoxied plane parts are
always pretty !!
Jay |
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Not a rust prevention solution but a unique rust removal solution using electrolysis. Google- gas tank rust removal using electrolysis.
I haven't tried a gas tank yet but have used electrolysis to remove rust from iron tools and other objects in a washing soda in water solution. |
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3073 |
I used electrolysis to clean the inside of a 100 gal transfer tank last fall. It worked good. Took almost 3 weeks though for a tank that big.
can you speed up the time it takes by using higher DC voltage? 24 verses 12
Thanks for all the replies. I guess I'll bite the bullet and take it off this winter and line it. I did line a CA tank probably 10 years ago and had no problems. Just didn't want to screw up the paint.
Leon B |
I don't know if voltage speeds it up, but amperage does. Mine could've went quicker if I'd cleaned the rust off the rods more often. I usually clean them only 3 times a day, before and after work, and before bed. About every 4 hours and it wouldn't cleaned much quicker.
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
Your tank wont rust unless its exposed to air. Keep some fuel in it and use Stabil if leaving set for a long time. I put a couple gallons with Stabil in every fall run the tractor and turn gas off let it run out in the carb. In the spring take off the sediment bowl and drain a couple cups out. the alcohol will absorb the water and it'll be in the bottom of the tank. add fresh fuel with Seafoam before starting and I've never had problems. My CA is the only tractor I coated the tank and it was leaking so I cleaned soldered all the pin holes and coated with Kream tank coating. Kream used to be available at motorcycle shops Now I'd use redcoat since it's more readily available
alan-nj ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: oxford, nj Points: 847 |
had a radiator shop coat a tank for me. turned my gas red for over a year. once the red cleared out, tank started leaking. cleaned it a bit myself and dumped a POR tank product in it. Stopped leaking, and gas is still normal color. don't know if the issue was the workmanship of the shop or the product, but i won't be going back there again.
If ignorance is bliss, than happy days are here again.
WDDave ![]() Silver Level ![]() Joined: 02 Jun 2016 Location: pa Points: 68 |
Im with Tim on not using StaBil, tried it for years in my generator, always turned off the shut off ran the gas out of carb and used StaBil in tank. Next time I tried to start it would run until it sucked up stuff in the tank and quit I had to take apart the carb every time. Now I just use non-ethanol fuel run the carb out of gas as before and has been fine past couple years. |
WD ,wide front, with loader
Tcmtech ![]() Orange Level ![]() Joined: 15 Apr 2015 Location: Minot ND Points: 310 |
That's largely my approach. Use the damn things like they were built to be used and use them often! ![]() Rust is an inevitable part of nature and old machinery so I just add the large clear G2 style fuel filters in the lines between the sediment bowl and carburetor on all our equipment to keep the fine sediments from reaching the carburetors. After that, at worst, I shut the fuel off at the tank and run the carb dry or drain it if it has a drain cock on it. Fuel wise I run primary E30 blends and have no trouble with any of my machinery sitting outside all winter with half a tank of that in it but then I make a point to have gas caps that actually seal too! It's amazing what tight gas cap seals do for moisture control!
I just add fuel filters to all my equipment with small engines. They're cheap and easy to work with and way easier to switch out when plugged than any carburetor is. Well worth the $1 - $2 they cost and solve a lot of problems.
StaBil turning hard like red clay completely stopped up my standpipe and petcock assembly so filter would not have helped there. With what I got out of my tank during draining/cleaning, likely something that should be done every year or two anyway on a working unit with the current gas situation. If I could justify the cost of Avgas use for everyday use I would do it.
Thinkin bout a Kubota 2.2L or smaller for an extra D15 Series One carcass I have, just for brush cutting use as the old Series Two 160's can eat a little fuel running 90-100% in heavy grass/brush in a ten hour day. |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3932 |
if they only get used once a year then just leave them totaly drained after the rust problem is taken care of now or totaly full with sta- bil in it and start them once a month for a half hour
Is it for sure rust? I've cleaned small engine tanks that looked like rust but it really was deposits from bad fuel allowed to evaporate with pour in the tank fuel injector cleaner. Let it sit with a bottle of cleaner in it for a day and see what happens. Just drain all the gas out first. If it's fuel deposits, it washes right out. Might be an easy clean up job.
From what I was told it probably wasn't cleaned up enough before they coated it. My d17 tank was a real mess the radiator shop I went to told me they hadn't seen one that bad in a long time and billed me for a double cleaning because the had to put the chemical cleaner in it twice to get it clean enough the stuff would stick. They also told me they used extra liner stuff. It turned the gas red for a long time but 7 year later I think it is still perfect. I think cleaning them up enough is tricky business. |
