Running/Marker Light ? |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: Running/Marker Light ?Posted: 16 Oct 2020 at 6:21pm |
Where are the "upper" marker lights supposed to be located on a P/U? I thought it was 5 lights on the leading edge of the cab, but Ford has 3 mounted on the upper grill of their "odd looking" Raptor that I've been seeing more and more of recently
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35679 |
Posted: 16 Oct 2020 at 6:49pm |
Should be highest facing edge of the factory built cab, Added bodies as sleepers and campers have their own. Raptor Lamps NOT for Marker just architectural enhancements.
![]() Edited by DMiller - 16 Oct 2020 at 6:51pm |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 16 Oct 2020 at 7:13pm |
Not sure if cab marker lights are mandatory on pick ups?
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 16 Oct 2020 at 7:25pm |
Marker lights are required on vehicles 90" or wider. Those Frog trucks can do what ever they like. Oooooh Shiny
The factories have gone to adding glitz and gimmicks to run the price up. 50 years ago you could get a fully outfitted 3/4 to that could actually last a few years and WORK for about $4,000 or less. Nowadays these things are full of plastic and computer controlled crap that is bound to break down before you can pay them off.Edited by PaulB - 18 Oct 2020 at 4:32pm |
FREEDGUY
Posted: 17 Oct 2020 at 5:44pm |
That's the problem, Ford put the yellow lights on the grill, why would they do that ?? I thought I was meeting a "tri-cycle" the other morning in the dark
Lars(wi)
Posted: 17 Oct 2020 at 5:49pm |
Was it a factory option, or something the owner did as a DIY?
FREEDGUY
Posted: 17 Oct 2020 at 5:58pm |
I've seen several Raptors (becoming more and more of them) with the same "marker lights" on the top of the grill.
DMiller
Posted: 17 Oct 2020 at 6:06pm |
They are not "Marker Lamps" They are Ford Dress out accessories. Marker lamps go ON THE CAB.
FREEDGUY
Posted: 17 Oct 2020 at 6:10pm |
Why are they YELLOW??? To me that's a MARKER LIGHT ??!!
If they aren't "marker" lights, they should be PINK !!!! Edited by FREEDGUY - 17 Oct 2020 at 6:12pm |
Joined: 11 Sep 2009 Location: illinois Points: 90826 |
Posted: 17 Oct 2020 at 6:56pm |
Most aftermarket grills for trucks and now putting 3-4 little yellow LED lights on the top edge below the hood.... Like DAVE said, its window dressing.. No value at all.
Posted: 17 Oct 2020 at 7:02pm |
FREEDGUY
Posted: 17 Oct 2020 at 7:06pm |
It's not the "value" issue, it's legality of where/how many of them(lights) there are on this Jeep/Hummer abomination of a "truck". I can't say for sure if they were A/M grills or not though
FREEDGUY
Posted: 17 Oct 2020 at 7:08pm |
Is this considered "after market" ?? Yes ,that's the configuration that approached me
Posted: 17 Oct 2020 at 7:20pm |
There are a zillion of them on e-bay for sale for $200. You can get them for ANY manufacturer of Truck... Lots of guy buy them to replace the factory CHROME grill to make a BLACK OUT..... for looks .... like the RAPTOR.
shameless dude
Posted: 18 Oct 2020 at 12:29am |
pink? someone say pink???
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 18 Oct 2020 at 6:11am |
any colour as long as they're not flashing red/blue.......... ..though they do look silly,serve NO purpose, cept send money to China. that being said, DRL ( Daytime running Lights) , are NOT legally required up here in Canada..somehting that was PROVEN to have saved lives...sigh... Jay
TomC
Joined: 24 Nov 2017 Location: Hillsboro, MO Points: 1549 |
Posted: 18 Oct 2020 at 6:12am |
Yes they did,, I just figured someone's slip was showing.
DMiller
Posted: 18 Oct 2020 at 6:31am |
Nothing illegal of Amber Accessory lamps to front or Reds to Rear, Nobody cares as stated Unless Flash as Emergency Vehicle Lamps. Can add a Hundred lamps to a machine and DOT does NOT G.A.S. unless are not working.
![]() Most of these lamps are NOT Required and yet if NOT Working can be fined for as Inoperable lighting.
DMiller
Posted: 18 Oct 2020 at 6:35am |
No reason but bragging rights for this
FREEDGUY
Posted: 18 Oct 2020 at 3:38pm |
DMiller, I can appreciate ALL of the lights and "bling" on a big rig
, but even in your pics, there's not ONE amber light on the middle of the grill ?? They are all "high and wide" other than the under front bumper lights .
DMiller
Posted: 18 Oct 2020 at 3:55pm |
See them In grills, around grills across grills. They mean NOTHING, just Bling. What do you not get of that, is Just a Accessory Lamp.
ONLY required are IF NEEDED by Truck Category, two front and two rear Corner Markers and Five Cab &/or Box Markers, TWO Tail Lamps TWO Stop/TS Lamps Two Front TS Lamps and by year a Alternate THIRD Or Upper BRAKE Lamp. PERIOD, GRILL Lamps are BS Bling. READ: Edited by DMiller - 18 Oct 2020 at 3:59pm |
Posted: 18 Oct 2020 at 3:58pm |
I have seen the light show setup as a CROSS or FACE in the center of the grill also.. Its all SHOW... SO WHAT ?
DMiller
Posted: 18 Oct 2020 at 4:01pm |
Or like this:
![]() ![]() Means NADA
Edited by DMiller - 18 Oct 2020 at 4:02pm |
DMiller
Posted: 18 Oct 2020 at 4:04pm |
THIS is the CFR(Code of Federal Regulations) for TRUCK Lighting, Raptors are LARGE Toys and oversize Cars.
Edited by DMiller - 18 Oct 2020 at 4:06pm |
TomC
Posted: 18 Oct 2020 at 4:23pm |
I had mine pretty well lite up,nothing like that but enough to where I had myself convinced it would give the OTHER 75% something to see and guide them when they tried backing in next to me.
FREEDGUY
Posted: 18 Oct 2020 at 4:28pm |
Your "CROSS" or "FACE" is pretty much a solid row of lights, the 3 "individual" lights on the raptor are deceiving IMO is all
PaulB
Posted: 18 Oct 2020 at 4:39pm |
in many sates anything other than clear or amber facing forward and red or amber facing rear (except for clear lights when in reverse gear) is ILLEGAL!!! It's right there in the vehicle law book published by the states MVA. Although for Barney Fife to do anything about is is another problem
