Rotobaler electric overdrive clutch
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Topic: Rotobaler electric overdrive clutch
    Posted: 20 hours 29 minutes ago at 6:17am
Pulled the overdrive clutch apart today. In between the magnet and the rotor, i fould four pieces of what i thought was some kind of a spacer that broke. Now i am not so sure it is broken. Each piece is exactly 90 degrees of a circle. They are 3/8 of an inch thick and an inch wide. They are all exactly the same size and i am pretty sure there is orange paint on the ends. Its not made of a metal i recognize, maybe there are carbon? Anybody left alive with experience?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 34 minutes ago at 4:12pm
Never worked on a rotobaler electric clutch, but in the lawnmower world there is such a thing.  Sounds like the asbestos(likely) has un-bonded from the steel...Wink
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 4 minutes ago at 7:42pm
Any idea how i ahould rebond it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 50 minutes ago at 7:56pm
epoxy ??
clean both side really,really good, then once more for me THEN  epoxy and LEAVE TO CURE for at least 2-3 days.
This page was generated in 0.176 seconds.
