roto baler question |
jlogli ![]() Orange Level ![]() Joined: 12 Oct 2011 Location: Stockport, IA Points: 856 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Sep 2012 at 5:34pm |
Why is there a letter at the end of the serial #? The twine guides are different than the other roto balers that i have seen in the past.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Austin(WI) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wisconsin Points: 1460 |
S Stands for standard I believe. There was a time when they made the Non-Stop and then just your standard Roto Baler. Hopefully someone else can confirm this. As for the twine guides...not sure. Something that someone had rigged up on the baler perhaps?
"Better By Design"
I looked up your serial # shown 9401 would make it a 1948 model, but that wouldn't make sense with the "S" as the fast tie models didn't come until the 1950s.
"Better By Design"
The twine guards look factory. It has a little spring that keeps tension on it. (right side of assembily)
JimIA ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Castalia Iowa Points: 1980 |
That is an aftermarket attachment. I have seen them before. If memory serves me right they were supposed to prevent twine catching where it would in the standuard guides. Years ago there was a set on a baler at the show in Belmond Iowa. They had some issues with them that day and they took them out.
As far as the S I am not sure. Jim |
bump
