Roto baler discharge springs |
500592
Topic: Roto baler discharge springsPosted: 29 May 2025 at 7:52am |
I recently picked up a roto baler that seems to be in decent shape and I have received a spring kit form agrisom already along with a manual but my trouble is I am missing both discharge springs on the back. Are those available somewhere or would a garage door spring work? These are pretty rare in my area so spare machines are hard to come by let alone someone who’s ever used one!
Thanks |
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3132 |
Posted: 29 May 2025 at 11:48am |
I have several Roto Balers for parts,sure I have some springs
500592
Posted: 29 May 2025 at 2:42pm |
If you don’t mind checking and would be willing to ship to Maine that would be awesome. Still tempted to try a garage door spring. Weather is starting to look better to get hay on the ground and want to try it out before I commit to cutting any. Any thoughts on how rugged the discharge spring are?
Gary Burnett
Posted: 29 May 2025 at 9:34pm |
I have never seen one of those springs that was broken,don't think a garage door spring would be nearly as strong/stiff.Will check when I get the chance.
500592
Posted: 30 May 2025 at 1:07am |
Thanks Gary. My other thought was a trip spring off a snow plow. The springs on my baler are missing completely so I’ve got no idea what size they possibly were. Was hoping someone had been through it before.
dr p
Joined: 24 Feb 2019 Location: new york Points: 1465 |
Posted: 30 May 2025 at 5:59am |
A rotobaler is the most rube goldberg piece of farm equipment ever invented. Trying to use a non original part is a sure to induce a high degree of anguish or end up in the b section of the newspaper. I have a couple of springs on the shelf and a whole lot of other nos parts if gary can't help you out. Sadly, most of the brainpower for the rotobaler is no longer with us. A drawback of using a 70 year old machine. Good luck!!
Gary Burnett
Posted: 30 May 2025 at 7:06am |
If you have some already ready to go I'm fine with you fellows making the deal as I'm not really equiped to ship parts.
Mikez
Posted: 30 May 2025 at 7:58am |
What’s the part number of spring
500592
Posted: 30 May 2025 at 8:12am |
I’m probably being impatient trying to get this thing going🤣 I’ve only seen one other rusted out one in person besides the one I bought I’m sure I will have a lot of questions when I get everything priced together. Probably will only do a few hundred bales a year if I can get it going. If not it will look nice parked next to the rest of the orange stuff 🤣 Unfortunately my owners manual doesn’t call out the part number only that they are the discharge springs. |
500592
Posted: 30 May 2025 at 6:23pm |
I made a couple calls today but nobody had a set of springs. If someone has a couple they are willing to ship to Maine please pm me. Thanks!
Gary Burnett
Posted: 31 May 2025 at 5:26am |
To be clear are you referring to the two springs that hang on the upper rear of the baler that can be hooked and unhooked?
500592
Posted: 31 May 2025 at 5:55am |
Correct Gary I think dr.p is going to send me some unless we are thinking different springs…
500592
Posted: 31 May 2025 at 6:03am |
500592
Posted: 31 May 2025 at 6:04am |
Hopefully the picture came through I circled the springs in red.
Gary Burnett
Posted: 31 May 2025 at 6:38am |
That is it,they need to be unhooked when the baler isn't in use.AC made a special tool to hook/unhook them but a claw hammer works fine.Also #1 thing on those balers is before EACH time you use it tap the side of the brake to make sure its not stuck,if its stuck when you start to make a bale it can do major damage.
dr p
Posted: 31 May 2025 at 6:56am |
I never knew they made a special tool. I think ac was the leadee in options/ accessories.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8759 |
Posted: 31 May 2025 at 7:03am |
I have been around roto balers for years, and I did not know that those springs were supposed to be unhooked when the baler is not in use. I don't remember reading it anywhere in the operator's manual. Never seen them unhooked on the 100 or so of them that I've seen out of use. Guess that I learn something new every day. Better start unhooking them on the one that I use.
Darrel |
Gary Burnett
Posted: 31 May 2025 at 7:14am |
We always unhooked them to relieve the tension so they didn't take the tension out of the springs,maybe not really necessary but doesn't hurt.The tool has a sort of hook on one end to unlock the latches and a round hoop like a handle on the other end.The balers had a bracket on the left rear to hold the hook.
500592
Posted: 31 May 2025 at 7:47am |
That would make sense as to why mine were missing. Supposedly the previous owner purchased it from an older gentleman who had used it and was unable to anymore so they must have been misplaced. The brake was the first thing I checked and it was loose so I did oil things up and hooked it up to my 45 at idle and got things moving. Figured after sitting so long it would be good to work some fresh oil and grease into things before putting a load on it. It did trip and drop the twine arm and all the belts seem to track good. I did buy a set of lower belts as those don’t look so great and didn’t want to be dead in the water because a belt broke.
Thank you all for the help. I’ve wanted one of these roto bakers for years and have only seen a handful come up for sale and this one happened to be in okay shape and at a price I could stomach. I’ve got a square baler for back up but hoping to roll a few bales up for my finances goats…… |
dr p
Posted: 01 Jun 2025 at 5:54am |
Gary, thought that "toad sticker" was for pushing the loose end of the string into the bale so it doesn't unravel. Went out to the shop and put the springs back on in 30 seconds (usually its a hassle) learned something. Thanks
Darrell read the manual again. It's in there. |
Gary Burnett
Posted: 01 Jun 2025 at 7:00am |
Probably was we never tucked the twine in the bale but used it plenty to trip the latches
dr p
Thanks(1)
Posted: 02 Jun 2025 at 8:18pm |
Mailed them today
500592
Posted: 02 Jun 2025 at 8:33pm |
Thank you dr! Please pm me what I owe ya!
Any other tips for a first time rotobaler owner/operator? |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8761 |
Posted: 02 Jun 2025 at 11:14pm |
...all I remember was the brake must be tightened to make a tight bale and you need to loosen brake when not in use.
500592
Posted: 08 Jun 2025 at 6:35pm |
Big thanks to dr.p for sending em discharge springs and Gary agrisom on for the spring kit. Ran a couple old square bales through it and to my amazement it kicked a bale right out the back and reset to make another! I only had some plastic twine kicking around so I need to get some of the right stuff but it seemed to feed okay anyways.
The lower belts worked but are definitely ragged and should be changed. I have some from shoup does anyone have tips on getting those installed? Just need to get a stretch of dry weather and I’m gonna mow a couple acres to really give it a test. |
500592
Posted: 08 Jun 2025 at 6:42pm |
dr p
Posted: 08 Jun 2025 at 8:19pm |
Its great that did as much as it did, but when you get to "fine tuning", it shouldn't have that much string on one side of the bale
dr p
Posted: 08 Jun 2025 at 8:24pm |
As for replacing the belts, that can be a tough one. The guy on this forum who taught me the most about rotobalers said you can't mix endless belts with spliced belts (one or the other) endless belts definitely work better but its a lot more difficult to find and a couple day job to install
