Rotella 30 SAE
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: Rotella 30 SAE
    Posted: 03 Feb 2022 at 6:43am
Anyone using the new Rotella 30 SAE oil that Walmart is now selling. Specifically designed for older diesel tractors turbo and non turbo? Sounds like just what I need in my 160 as it calls for straight 30 weight. Need to research it to make sure it contains the higher zinc level for the cam.
Sherman Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2022 at 7:36am
Can't get any flavor of Rotella from Sam's club, Tractor Supply, Rural King or any other discount store in this area. Some high end retail stores have it for $25.00 a gallon.
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2022 at 7:42am
Your mighty "One-Sixty" calls for SAE 30 wt diesel oil because 15W-40 hadn't been invented yet. They never re-write the owners manuals. Modern day 15W-40 would be just fine as long as the zinc levels are over 1,000 PPM for flat tappet camshaft engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2022 at 8:31am
That’s a good point Dr, I’m getting ready to change out the break in oil after the complete engine overhaul. Trying to figure out the best oil for it. I use the Rotella 15W-40 T4 in my 190XT. Wish the zinc levels were on the container.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2022 at 8:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2022 at 8:38am
Dr is right.. That 15W would sure help for cold startups... And the 40 is a great summer oil.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2022 at 11:42am
I have been using John Deere 15w-40 in my farm equipment, for years. JD 4050, D-17 gas, 180 diesel, CII combine propane.
Seems to work just fine.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2022 at 12:26pm
But as every one is saying you don't want the NEW FORMULA that is made to not clog the clean air add on stuff. I say any brand you have used for years will be ok, as long as it is not the NEW clean air DEF compatible. But Rotella has 2 maybe 3 different formulas.
Wink If you pull the stick and there is nothing on it Confused and you just have to start it. Ouch I beat the new stuff would be much better than none. But if you got old machinery, you need to keep a few things around. So take time know what the S A E grades are besides 30wt or 10-40wt but the capital letters in the circle.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2022 at 3:04pm
Rotella 15w-40 and 10w-30 are still 1000 ppm zinc phos last I checked. Motorcraft super duty 15/40 and 10/30 are as well. Delo and Delvac are low (800 ppm) zinc/phos.Most diesel oils carrying both ck4 and sn api service ratings are low zin/phos witch aren't good for old flat tappet engines.BUYER BEWARE and do your homework before you buy.Most brands product data sheets can be found online. Another good source of information is Petroleum Quality Institute of America.  http://pqia.org/
Edited by ac45dave - 03 Feb 2022 at 3:29pm
cottonpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2022 at 8:35pm
Delvac MX 15w-40 is CI-4Plus.
Edited by cottonpatch - 03 Feb 2022 at 8:36pm
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2022 at 8:27am
Rotella T 15W-40 T4 has 1200 ppm zinc, so I will stick to with that. I use it in my 5.9 Cummins in my Ram truck and my 190XT. Thanks for the input everyone, was interesting seeing the Rotella in a 30 SAE and was curious to everyone’s input.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2022 at 8:31am
Rotella 30 SAE is (low) zinc/phos 800 ppm, not a good option for flat tappet.This was told to me straight from the folks at shell.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2022 at 9:10am
I've seen the Shell Rotella 15w40 and 10w30 at Menards, TSC and Orscheln locally.  Menards usually has the best price.  As of lately, they seem to have been running short of it.  I suppose supply side issues.
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2022 at 11:25am
You can always use an additive like this, which works great.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2022 at 12:12pm
Am I right thinking my gas D 15 engine needs a high zinc oil ? Last oil change I used TSC 10W40 . Don't see anything about zinc % online . THANKS !
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2022 at 12:24pm
Zinc (or lack thereof) is not a concern for slow tractor engines with relatively low valve spring pressures…
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2022 at 12:30pm
Local tractor mechanic guy recommended Rotella 15w40 for even my gas tractors.  I never switched my '45 to that, but rather use Rotella 10w30 in it.  It turns over slow enough in the winter with the six volt system!
ToddnwIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2022 at 12:59pm
I had an elderly neighbor that always told me any oil is better than no oil... he also lived by check the oil and the water you will know when your outa gas!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2022 at 1:45pm
Thanks guys !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2022 at 12:33pm
On some of my old Cat's if there is fresh oil leaking on the final drive Thumbs Up they have oil good to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2022 at 8:43pm
Must be some type of shortage on the Rotella 15W-40, can’t find it anywhere locally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 2:21am
i bought my last 55 gal barrel of Rotella 15-40 at Sams club. they were cheaper than anyone else
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 7:58am
Have heard that the additives they use are in short supply. Bought one 5 gallon bucket last fall, glad I did!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 8:14am
looked on line and local Menards has 20 jugs of 15W40 ...... also some at Wal Mart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 9:03pm
3 Walmart’s within 30 miles of me are out. Autozone, TSC, Advance, Costco are all out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 4:06pm
Rotella  15/40 is back on the shelf at Rural King in Mt Vernon Ohio.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 4:06pm
Don(MO) was posting a few years ago that we was seeing gas AC tractors wiht worn cams. Likely because of low Zinc levels. I think it's important for gas to. Don was one of the best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 4:47pm
I also had a mechanic say that one of my vehicles needed/would benefit from the oil with zinc in it.  He suggested using the rotella 10w30 in the car.  Maybe zinc does have a benefit for the gas engines, also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 5:27pm
the problem with using oils that have high ZINC in them in NEW CARS is that the zinc will destroy the catalytic converter.......... Oil blowby is burn off thru the PCV system into the exhaust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 6:15pm
I don't believe using high levels of zinc in any pre-1990's gas or deezel farm tractors is a bad thing.
