Ross vs Gemmer
tim 1938 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tim 1938 Quote  Post ReplyReply Direct Link To This Post Topic: Ross vs Gemmer
    Posted: 06 Nov 2011 at 7:20am
OK guys  I have a Gemmer steering box on my 1940 model B . need the lower bearing but am not going to buy 600 bucks for the bearing  so can I put a Ross steering unit on it and it work   thanks Tim
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2011 at 7:54am
You may have to change everything between the steering wheel and drag link, including the tool box because it's all different part #'s. Not sure if any parts interchange between them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2011 at 7:57am
$600. ??  I would think there are other possibilities, or i would put a bronze bushing in before i paid that.  Yes the boxes are interchangeable, but you need to keep the original drop arm that goes to the steering link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tim 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2011 at 1:31pm
I do not have a tool box for the tractor yet  that was one of the issue I had  I didn't want to get one tool box then have to get the other one thanks for the input  Tim
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2011 at 2:16pm
The tool box for the Gemmer has the larger opening so putting on a ross would not be a problem.
I make my own tool boxes. I took old rusted ones and flattened them out for patterns.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2011 at 9:39pm
I went to a bearing supply and bought the bearing for about $30.00. We looked it  up in the Timken book. I don't know where your looking. but I qould be looking elsewhere. I had to replace both bearings and the races. Bob
This page was generated in 0.976 seconds.
