Ross Steering Box
ACJohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACJohn Quote  Post ReplyReply Direct Link To This Post Topic: Ross Steering Box
    Posted: 13 Feb 2012 at 1:39pm
I have worked on Ross boxes on B's that needed very little help.  Now I'm into a G box and it needs all the help I can give it!  Was the input (worm) shaft cover shimmed to set the thrust bearing preload?  Was there ever a seal in the input cover neck?  I've straightened the bent shaft, polished the bearing races, replaced the balls on the upper end, and am ready to assemble.  I'm going to bore the input neck for a seal as I don't see how oil would not slop out.  The front wheels won't know how to act with no slop!!  Thanks in advance for any insight.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 9:16am
John,
 The cover is shimmed for the bearing just like the B, in fact I think the gearbox is identical to the Ross B except for the length of the steering shaft.
 I too cannot see why there is no seal in the shaft cover, as I can't fill the gearbox due to the gear oil runs out to that level.
Bill B
This page was generated in 0.057 seconds.
