Ross Steering Box Rebuild
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Topic: Ross Steering Box Rebuild
    Posted: 22 Aug 2011 at 2:34pm
What grease are you guys using when you rebuild the gearbox?  And where is the best place to get it?
Andrew
Edited by 1953CA - 30 Aug 2011 at 4:15pm
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 4:16pm
BUMP
George R. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George R. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 6:29pm
Andrew,
The owner's manual for the CA specifies 140w gear lub.  When I rebuilt the ross steering box on my Dad's CA I used the 140w.  If I remember correctly I bought it at Tractor Supply.  Although I have seen some fellows insert a grease zerk where the fill plug goes and pump it full of chassis grease.  I guess it works either way.
My tractor is not leaking oil, it's just marking it's territory!
