roller pin removal |
wlambs
Topic: roller pin removalPosted: 01 Oct 2023 at 1:32pm |
Tring to get pin out of snaping roll on 238 corn head so i can replace needle bearing used punch and hammer got it to move very little any suggestions not sure whether to use heat on pin
185,6080,6060,72 allcrop, roto baler
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 726 |
Posted: 01 Oct 2023 at 2:17pm |
Its been 30 years since I worked on one of those but it seems like those pins were tapered and only came out one way
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
8070nc
Posted: 01 Oct 2023 at 2:19pm |
If its a hollow pin thats not it. If its a solid pin its a possibility
1984 80780
wlambs
Posted: 01 Oct 2023 at 3:44pm |
it is solid and tapered a little on one end
8070nc
Posted: 01 Oct 2023 at 5:24pm |
I meant its tapered thru the whole bore
If it is a tapered pin it will be smaller on one end than the other Kind of hard to tell sometimes if it got bradded when it was driven in |
1984 80780
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3671 |
Posted: 01 Oct 2023 at 6:11pm |
238 orange? Or 238 black?
wlambs
Posted: 01 Oct 2023 at 7:29pm |
black adjustable row
AC7060IL
Posted: 02 Oct 2023 at 7:28am |
Gleaner Black Cornhead Parts book form 9004918, March 1977 lingo as follows:
POINT(cast cone shaped spiral?) EXTENSION (cast transition behind needle bearing housing placed before blade set). Try heating snapping roll point’s (spiral cone?)pin(groove 5/16”-2 1/8”)to cherry red then hammer/punch out? The last one I successfully hammered pin out without any heat, I used a stout 1/4" punch to move pin back & forth while applying penetrating oil onto/into pin & hole. That took time. Even had a helper manually wrench cornhead roll 180 degrees by using an open end wrench on hex drive shaft, as I stood between row frames. Important note: If removing both rolls entirely per row, keep points/extensions properly matched. LEFT POINT is long & is matched to a short extension. RIGHT POINT is short & is matched to a long extension. Needle bearing part # 560985 Needle seals(2), 560254 Edited by AC7060IL - 02 Oct 2023 at 7:54am |
wlambs
Posted: 03 Oct 2023 at 6:36am |
thanks for answers heat and air chisel worked good. was afraid to put heat on it at first
