Roller Mill ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Roller Mill ?
    Posted: 22 Sep 2020 at 7:40pm
There's one for sale on our local C/L, I am unfamiliar with this tool, what does it do ? I "assume" that it's different than a portable sheller ?? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 9:31pm
you run the grain thru it and it sciwshes/flattens it out. kinda makes the grains look like small corn flakes. it doesn't grind the kernals
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 7:39am
Some do a little more than that, the multi-roller units run the rollers at different speeds so as to crush and tear the grains apart, the larger mills separate grain kernels from outer sheath or Germ and can then crush to a flour consistency cleaner/faster with less Grits.
Worked a short time at Siemer Milling Teutopolis IL, mechanic on their rental road equipment.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 9:55am
Makes better feed than hammermill  or burrmill.
