Rod bearing wear |
Acguywill
Joined: 15 Jan 2024 Location: Vauxhall ab Can Points: 195 |
Topic: Rod bearing wearPosted: 01 Feb 2026 at 1:15pm |
So this is a picture of a rod bearing from the engine I had the antifreeze issue with.
![]() All six bearings have the same mark in the same place. What caused it? It is deep and can easily be felt. The crank looks and feels fine. |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5170 |
Posted: 01 Feb 2026 at 1:35pm |
Antifreeze has/is glycol. Glycol is in the glucose (sugar) family. Antifreeze in the oil reduces the ability of oil to lubricate the crankshaft.
At a very minimum, you have to first eliminate the coolant in the oil. I would change the rod and main bearings. The crankshaft should be measured (miked) to see how out of round it is.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8366 |
Posted: 01 Feb 2026 at 2:58pm |
Ouch!! |
bigal121892
Posted: 01 Feb 2026 at 3:46pm |
You said the engine had been sitting for four years, I wonder if just the fact that the crank was sitting in that one spot for that long, could have done that.
Les Kerf
Posted: 01 Feb 2026 at 3:47pm |
That doesn't look like frictional wear but rather more like a chemical reaction dissolving the bearing material
Acguywill
Posted: 01 Feb 2026 at 5:09pm |
The bearings looked like that when I parked it. I thought it looked like chemical etching but can't figure out why or how they could all be in the same place, the holes for the oil don't line up in the same place on the bearings. I couldn't find new bearings at the time so it has just been sitting but have recently found some so am looking to get it ready as a spare/backup. Not that it makes any difference but it is an international UR450 power unit. The date on both the rod and mains is 6 74 so it has been a while since it's last overhaul. Forgot to add there was no antifreeze in the oil when I checked it 4 years ago and there is none in it now so thankfully the block did not freeze.
Edited by Acguywill - 01 Feb 2026 at 5:12pm |
Posted: 01 Feb 2026 at 5:30pm |
If you're going to re-use them, switch them around, top shell to the bottom and bottom shell to the top.
Acguywill
Posted: 01 Feb 2026 at 6:00pm |
I had thought about that, but the bad spot is on the bottom shell as it is and the edge of the spot is very abrupt. I was worried that if I ran it the bearing material would continue to break down and destroy the crank. Parts for old International engines are getting scarce.
Posted: 01 Feb 2026 at 6:44pm |
OK. I assumed your "sweet spot" was on the upper shell like many engines are.
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2590 |
Posted: 02 Feb 2026 at 11:03am |
this may help point you in the correct direction.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Les Kerf
Posted: 02 Feb 2026 at 2:15pm |
Thank you for that excellent link! The photo in the section about corrosion does look a bit like the bearing that the original poster has, but it also shows some similarity to the example with foreign particles on the back of the bearing. It seems unlikely that there would be foreign particles on the back of all six bearings in the very same spot. Could someone have previously filed down the bearing caps, resulting in an out of round bore? I would be measuring those bearing bores very carefully.
Acguywill
Posted: 4 hours 30 minutes ago at 7:48pm |
Thanks for the link Acdiesel. Reading the descriptions of the various types of failures I am thinking it is surface fatigue. That seems to be the only thing that fits what I am seeing. That would explain why there are bits of stuff imbeded in the bearing surface. I originally thought they were contaminants of some sort but when I took a close up picture and really zoomed in they look like flakes of surface material. Not shiny metallic flakes but dull colored angular shaped flakes.
