Road Speed Of Combines ?? |
Post Reply | Page 12> |
FREEDGUY
Orange Level Access Joined: 15 Apr 2017 Location: South West Mich Points: 5391 |
Posted: 16 Sep 2021 at 6:46pm |
Talked with a friend of mine that took possession of 2- 2 year old N/H combines that said their "road" speed is 25 MPH !! Is this common for all class 7 and above machines for road travel ??
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7981 |
bet you could google it.
FREEDGUY
So you don't own/operate one ?? I was "hoping" for O/O input !!
SteveM C/IL
I think my 'new" R62 goes over 20....that was January when I drove it home so memory ain't there.
FREEDGUY
Thank you !!
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13611 |
drove an N5 about 18 miles one day, it went about 35 MPH. was clocked by the vehicle following me. didn't bounce all over like some do at 15-18 MPH. one of my "G" combines would do about 20, and the other did about 15, same tranny in both. the one that was the slowest was squirely on the road.
Daehler
Orange Level Access Joined: 23 Nov 2010 Location: Lexington MO Points: 1152 |
Most Gleaner rotaries have been running 22 to 25 since the N series. Anything with a 30.5 32 tire or bigger have been at least.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
Brian Jasper co. Ia
Orange Level Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
It’s a good thing I don’t have to road my E anywhere because it’s snail slow on the road. It might be 10 mph...
MACK
At 25 mph, better have all good linkage on steering. Any thing that steers by rear axel can be squirely on the road. MACK
MikeKroupa
Bronze Level Access Joined: 12 Sep 2009 Location: pierce,nebraska Points: 72 |
Our S78 and S97 do 23 mph plus. Hammer down to the next field!
wekracer
Orange Level Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1587 |
My L2 rolls down the road 23 mph if you brave enough
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3198 |
Yes. Probably best to road drive any newer rotor combine with your hand/fingers on their throttle/engine rpm speed buttons(1,2,3 rpm settings)to quickly reduce their top-end speeds, if situations demand it. IMO-Engine speed reductions usually make for safer/gentler drivetrain maneuvering than pulling back on transmission hydro lever at high idle.
The newer Gleaner rotor combines(maybe other brands too?) have more rear steer axle weight than the older conventional combines. So rotor’s additional weight distribution probably allows them better steer control for higher road speeds? Try roading an older conventional gleaner with an attached cornhead, in high gear. Fifteen mph & things could get interesting because it may not have had enough rear axle steer tire weight. On the other hand, the older 2wd conventionals transverse soft soils if equipped with wider float tires because more of their weight is concentrated on their drive axle. The larger rotor gleaner’s rear wheel assist is much needed in soft soils because of their increased base machine weights too. The L2 weighs 14,700lbs. An N6 weighs 18,820lbs. An R52 weighs 20,840lbs An R75 weighs 28,500lbs. An A85 weighs 37,700lbs. An S77 weighs 29,740lbs. An S98 weighs 33,920lbs. Think these weights are high? Some competitor brand combines can easily add upward of 10,000+ lbs to the Gleaner weights! Edited by AC7060IL - 17 Sep 2021 at 6:25am |
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11388 |
Not sure if you're crazy, full of BS, or actually stupid. Sorry.
Orange Level Access Joined: 12 Sep 2009 Points: 19505 |
Maybe 35 Kilometers per hour, which does calculate to 21.75 miles per hour which is more like it?? on a dual read speedometer maybe the driver was cornfused ??
Tbone95
Much more likely, and a plausible explanation.
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4346 |
I believe you I might of had a MH up to that speed. Broke the hydraulic drive belts and the hydro free wheeled and away I went down the hill. Thank fully It did not tip over when the up hill steering brake garbed. Just bounced a few more times and slowed as I contoured it into the hill. We moved as many as 4 MH2's down the road. The oldest most hours machine first to set the pace. The hydro's get slower the more warn they are. They all did a bit over 20 mph. Moved 2 and 3, 50 miles or so at a time, a lot of that on the 4 lane California 101 highway. Then they added a JD 6622, that thing would not do 15 mph. Over the years drove 6 different MH2's. One was always a little more squirrely going down the road than the rest. Several wanted to bounce the back axle more as they aged. We played with things never got like new. Also tried to keep water in the rear tires. But with repairs and all did run down the road with only one watered sometimes, it mattered.
FREEDGUY
WOW Shameless !! The "quickest" machine that I drove down the road was a neighbors Case Diesel 630 with Triple Range, 28 MPH !! Was your N5 "naked" or did it have a header on it ??
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 6639 |
If I’m not mistaken, some Uni’s had a suitcase rack for weights on the rear-end.
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50526 |
We all know ole Shamers sometimes "exaggerates" a little, now and then...
Here he is balin hay! |
bigal121892
Orange Level Joined: 05 Jan 2010 Location: Nebraska Points: 738 |
Well, that would certainly explain a few things!
Gregor
Silver Level Joined: 11 Sep 2009 Location: Prague, Ne Points: 305 |
Years ago, I bought a N6 at a consignment action and neighbor bought a 1660 CIh. We picked up the same day and drove home about 20 miles. He had about a 10-15 minute start on me. I caught up to him about 10 miles down the road and I was not maxing out my speed. He was. We still chuckle about that day over a beer now and then. 1st and only time he was passed in a combine by another combine.
Ron(AB)
Orange Level Joined: 27 Dec 2009 Location: Alberta Points: 943 |
Re: the baling vid
Wow! Don't try that at home! Edited by Ron(AB) - 20 Sep 2021 at 2:04pm |
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
CrestonM
Orange Level Joined: 08 Sep 2014 Location: Oklahoma Points: 8357 |
My L3 says it does 27 mph, but the app on my phone says 23.
I’ve ran Deere 7720 and 8820 for a friend and they’re 12-14 mph. |
Tbone95
Never thought I'd have to worry about speed rating of ag tires, and to have them balanced when mounted!
L-3's don't do 27 mph. Speedometer needs to be calibrated.
Tbone95
Not a combine, but the fastest ag unit we ever had was a Ford 6000 with the POS (er, SOS, dang I always screw that up) transmission. Been too long to remember but seems the tach/ speedo said somewhere around 28 mph? You DIDN'T want to actually go full speed, the rear tires would start rocking sideways, steering would get real squirrely, knuckles would start getting really white. Slow down, live longer.
Edited by Tbone95 - 21 Sep 2021 at 8:17am |
The mighty Ford 6000 Commander with the 10-speed SOJ (select-a-jerk) transmission !!!!
Tbone95
That would be the one!
DiyDave
Actually the Silver King highway mowers had a stock speed of a whopping 45 MPH! IIRR, that is the fastest of any stock tractor. I had a MF Turf 20, that had a top end of about 35MPH, that was just plain scary at speed, had bad tie rod ends, so I hadda put both feet against the tie rod ends near the console, to control the shaking at top speed! But I was younger, then!
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5637 |
An M-M UDLX would do 40...
