Road marker hole maker |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Topic: Road marker hole makerPosted: 03 May 2017 at 5:00pm |
Sons latest piece of equipment - going to Alaska on Friday - for installing marker posts on haul roads in oil fields -
2nd unit he has built for Alaska for installing - has 2 units for removing the posts also and the ice saw for installing markers on ICE-ROADS So my driveway gets used for test run of equipment . [TUBE]fYmfmhkMH_g[/TUBE]
omahagreg
Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2809 |
Posted: 03 May 2017 at 8:54pm |
That is neat!
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8780 |
Posted: 03 May 2017 at 9:36pm |
That's quite the mount with those thick rubber isolators. Darrel
shameless dude
Posted: 04 May 2017 at 7:46am |
man....keep your toes away from that thing!
Coke-in-MN
Posted: 04 May 2017 at 7:22pm |
Full unit extends out on slide in base so it can place vibrating chisel about 4' to side of machine . The vibrator (green box) is something he made up here in shop and the hydraulic motor is 1000 RPM or so and rated at about 20 HP .
Hard facing on chisel end for long life (hopefully) going by truck to west coast then by Air Freight to Alaska - both the installer and puller on one pallet |
