Road marker hole maker
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: Road marker hole maker
    Posted: 03 May 2017 at 5:00pm
Sons latest piece of equipment - going to Alaska on Friday - for installing marker posts on haul roads in oil fields -
 2nd unit he has built for Alaska for installing - has 2 units for removing the posts also and the ice saw for installing markers on ICE-ROADS
 So my driveway gets used for test run of equipment .
[TUBE]fYmfmhkMH_g[/TUBE]
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 8:54pm
That is neat!
Greg Kroeker
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 9:36pm
That's quite the mount with those thick rubber isolators. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 7:46am
man....keep your toes away from that thing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 7:22pm
Full unit extends out on slide in base so it can place vibrating chisel about 4' to side of machine . The vibrator (green box) is something he made up here in shop and the hydraulic motor is 1000 RPM or so and rated at about 20 HP .
 Hard facing on chisel end for long life (hopefully) going by truck to west coast then by Air Freight to Alaska  - both the installer and puller on one pallet
This page was generated in 0.170 seconds.
