Road Grader Help |
Post Reply |
Brinkley
Bronze Level Joined: 25 Jun 2019 Location: Colorado Points: 3 |
Posted: 25 Jun 2019 at 10:46am |
HI all.
Does anyone have any idea of model year of this grader? Im guessing late 40's early 50's. I purchased it and it's scheduled to be here tmrw. I'm trying to find svc manual on it. I found one for Allis-Chalmers 45 road grader but its not year specific. It looks like a 45 when i googled it. It has a new motor and everything is mechanical but the power steering. Round frame. I can locate alot of the grease fitting but I'm sure there's stuff i.ll miss. Thanks for any help Thomas
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3732 |
looks like an AD4 or AD40 with the 4-71 GM engine. these would be the predecessors to the 45 which had the AC buda engine. very similar models with changes to main frame, blade control box and other small items
Edited by CAL(KS) - 25 Jun 2019 at 10:50am |
DonBC
Orange Level Access Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 899 |
You may get more responses if you post this on the construction section as well. Just a suggestion.
Brinkley
Thanks I will.
AD3grader
Bronze Level Joined: 12 Dec 2019 Location: Windsor Ontario Points: 1 |
AD4
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7970 |
AD4...need a 6-71 for pushing V plow in big drifts
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50488 |
Look for the Data plate, on bottom rail of the cab, where you step up into operators position. Right side, IIRR...
SteveM C/IL
AD40 had 2 year levers up through floor.Pwr steering wasn't around when that was made. Should have electric brakes. A 40 was an improvement over 4. Moved gear boxes for better visibility.
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2201 |
Not a fourty five, I had one of them, also had 2 of the BD-3's, they had 3-71 detroits in them.
Post Reply | |
