Rings for WD
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: Rings for WD
    Posted: 25 Jan 2024 at 9:19am
Does AGCO still sell complete ring kits for a WD? Dealer says I have to buy one ring at a time or buy an overhaul kit.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2024 at 10:00am
I'd get with my favorite machine shop and buy a set of Hastings rings or a competitors.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2024 at 11:49am
have you pulled the pistons yet?
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2024 at 6:08pm
Yes. Had cylinders professionally honed just because my hone is shot. Head rebuilt, block decked because it was 7 thousands out of flat (maybe wasn't necessary) I thought 7 was a bit much and head gasket blew out in probably less than 200 maybe 300 hours. New seats and valves. I had an old, now passed, local mechanic do the valve jobs years back and one intake was burned out and a couple other valves in not too good of shape. Shop guy says an old worn out valve grinder will cause that. Anyhow I do have a set of NOS rings in an Allis overhaul kit but I don't want to use those because I have plans for that kit. This will be pretty much a complete overhaul job.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2024 at 6:10pm
Dr, I didn't know hastings was still going. Used to be the go to here in Rochester. I'll go to the machinist and see. I just don't trust most after market parts anymore.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2024 at 6:45pm
I have a lunch bag full of assorted NOS rings for the 4" pistons I'll sell cheap + shipping.
Edited by PaulB - 25 Jan 2024 at 6:45pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2024 at 8:19pm
I'll send a pm
Wink
I am a Russian Bot
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2024 at 2:43am
Hastings is where manufacturers go to get their OEM rings... if you buy an OEM kit, or an aftermarket kit, chances are pretty darned good they bought what they're selling you... from Hastings...Wink
1963D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1963D17 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2024 at 9:12pm
If it's the 4-1/8" overbore, A & I products stocks the ring kits. 21.40 per hole
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2024 at 11:29am
What do you guys think of this idea? WC's and WD's use three 1/8" thick compression rings. I considered using two 1/16" thick rings in each of 2 of the compression ring grooves and stagger the gaps. This duplicates a gapless ring. Also, use a .030" over ring in a standard bore and file fit the end gap to AC specs. What about using 2 of the compression ring grooves instead of 3 as do modern 4 stroke gas engines? Chrome Moly, Plasma Chrome Moly, or cast iron rings are another consideration. What's your thoughts?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2024 at 9:54am
Thanks folks. I found some nos from a forum member that I think I'll get.
Edited by Lonn - 28 Jan 2024 at 9:56am
Wink
I am a Russian Bot
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2024 at 10:17am
agco number for 4 inch  70230091 kit for 4 sets
hastings number 2c702
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2024 at 10:18am
have on hand thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 5:01am
Steve Fischer, are you willing to sell a set of rings for all 4 cylinders 4.000" Bore for my WC? If so price?
Edited by Phil48ACWC - 29 Jan 2024 at 5:42am
