Ring gear on D15D seems loose.
b170dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b170dr Quote  Post ReplyReply Direct Link To This Post Topic: Ring gear on D15D seems loose.
    Posted: 02 Apr 2012 at 10:56pm
I pulled the rear lift arm housing off 1960 D 15 D  last night to replace seal and hose on the ram.  Grabed hould of ring gear, could move the gear on the housing. Ring gear held on with rivits. There is play in the rivits.  Wonder if could heat up the rivit and musrune it some. Amy sugestions from you good wrench benders would be appreacated.  Thanks Roger.
'64 B-10, '58 D-14, '60 D-15D, '58 D-17D, D-19, 170, 2-185D, 190, 68 D-21 11, 72-220, 7000,7030, F-2 G,w/5 Heads,L-2 G, 330 No-Till
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 7:54am
There is a bolt kit to replace the rivits.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 8:17am
Sounds like something that needs immediate attention. It can get real messy and probably $$$ if things start coming undone in the differential.
