ring and pinion-whats it fit? |
Wes (VA)
Joined: 12 Sep 2009 Location: Elkton, VA Points: 510 |
Topic: ring and pinion-whats it fit?Posted: 29 May 2023 at 12:41pm |
In my pile of parts that I acquired from the dealer selling out a few yrs ago, I got this ring and pinion 5117045 and 5117046. I looked by tractor on agco parts but the number either changed or I didnt come across the right tractor. Thinkin it was a 185 or 190 or 200. I thoughtthere was a way to type in part number on APB, but I cant find it. Googled the number doesn't give me much either. Thanks, Wes
Posted: 29 May 2023 at 2:31pm |
Those numbers are not tractor numbers. Maybe a Super 100 self-propelled combine ??
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
Posted: 29 May 2023 at 6:50pm |
AC Ring gear and pinions come in a set with single pn unless it is for something really OLD- to the best of my knowlege. IF from an old dealer it would have been prior to adding the 70 in front AC always used 6 digit part #/s As in 70511704-5 - later they dropped the check digit at the end. as in rotary cutters, manure spreaders and possibly cotton products made at Laporte...
Posted: 29 May 2023 at 6:55pm |
180-185-190-190XT 2-pinion differential is 9 tooth pinion gear/shaft and 35 tooth ring gear.
Wes (VA)
Posted: 05 Jun 2023 at 1:37pm |
This is 9 tooth pinion, 41 tooth ring gear, with 12 mounting holes.
Posted: 05 Jun 2023 at 1:55pm |
If I could see a picture, I might be able to identify. But, as I said earlier, your part numbers given aren't for a tractor.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1506 |
Posted: 05 Jun 2023 at 7:53pm |
So that is 4.56 ratio. What model ran that? I see the WD is 3.5 to 1 and the WD45 is 3.3 to 1 according to the service manual.
