rims |
TennMatt1
Joined: 12 Oct 2015 Location: Southern KY Points: 71 |
Topic: rimsPosted: 14 Nov 2015 at 11:12pm |
i looked with very little success for a 8 lug....I just bit the bullet and bought a set of adapters from Pete Petznick. Around here 9 hole wheels are fairly easy to come by and in a wide variety of sizes. The adapters were a little costly but I believe worth the money.
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 14 Nov 2015 at 5:13pm |
acpuller I made spoke 15538 centers for my wd with floating ac logo centers
AC puller
Posted: 13 Nov 2015 at 3:47pm |
Thanks Dr.Yes i wanted 38 centers for a wd45. Thought u could buy them like a 9 inch. Ya i could easily fab that up.
Posted: 13 Nov 2015 at 12:25pm |
Your question is quite vague. I figure you must be wanting to bolt something onto a WD or WD45 ?? What SIZE wheel?? 28 inch?? 34 inch?? 38 inch?? I've always made my own pulling wheels by cutting out a 12 or 14 inch circle piece right out of the center of the original 28 inch spin-out WD wheel center. Then, I take a 14 inch wide by 38 inch dual wheel and cut out the 9-bolt hole circle at a diameter 2 inches small than the circle I removed from the WD wheel center. Overlap the two parts and weld on both sides. Is it easy ?? pretty much, if you are a fabricator of any kind. Is it cheap?? fairly so. If you just want to be able to purchase a wheel center and rim that will bolt right on to a WD.....search for junked out Massey's. They have some of those that will bolt right on with no mods. They will cost you some $$$ if you find any.
AC puller
Posted: 12 Nov 2015 at 8:29pm |
No supplier sells 8 bolt centers?
8070
Posted: 10 Nov 2015 at 7:28pm |
Make them we had to what size u looking for and do u want light wight ones if so I got a bubby making them they at 68 lb when he done but they or costly . If u want more info mess me .
AC puller
Posted: 10 Nov 2015 at 7:25pm |
Where's a good place to get 8 bolt pressed wheels?
