Rims are finally done |
Page <12 |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8708 |
Oh ok cool
alleyyooper ![]() Orange Level ![]() Joined: 12 May 2014 Location: Michigan Points: 238 |
Why sand blast when they dip them to remove the rust. Only paint needs removing so you spray the wheel with oven cleaner let it set for a bit and then hose or power wash off.
BrianC ![]() Orange Level Access ![]() Joined: 16 Jun 2011 Location: New York Points: 1619 |
Dennis,
That's the way to go. Were there any places where the zinc did not cover? |
DennisA (IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ridott IL. Points: 2069 |
Zinc coverage was really good. With the exception of The areas of the room that had heavy rust. Those areas are really porous which holds in the acid from the acid bath. Those areas want to weep out acid during the galvanizing process and leave blemishes on the surface. This is why we sand blast the rims so the acid has more of an even surface. The worse the rust is on the rims the more defects you will have on the surface after galvanizing.
![]() Edited by DennisA (IL) - 02 Oct 2016 at 10:38pm |
Thanks & God Bless
Dennis |
Thanks & God Bless
Dennis |
Hockeygoon ![]() Orange Level ![]() ![]() Joined: 13 Sep 2016 Location: Manhattan, KS Points: 1210 |
Nice
Do you not have the "blocks" that are pinned to the rail? Edited by Hockeygoon - 06 Oct 2016 at 3:15pm |
sandman2234 ![]() Orange Level ![]() Joined: 21 Feb 2013 Location: Jax Points: 2547 |
My rear Galvanized rims were used when I got them, but I know the sprinkler system that they came off of was installed before 1978. No rust on them, however my rims were custom built and then galvanized, so no previous rust to worry about, or need to sandblast. They are all dipped into a hydracloric acid bath because the acid gives the metal a little bit rough edge for the zinc to adhere to. Hotdip is also better because the zinc causes a chemical bond with the steel, instead of just applying a coating.
David from jax |
A proud member of the Allis Express movement!
Northeast Florida |
If you are referring to the wheel stopping blocks then yes I do have them I just don't have them put on yet. |
Thanks & God Bless
Dennis |
Page <12 |
