Reverse WD Power steering
posse_99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote posse_99 Quote  Post ReplyReply Direct Link To This Post Topic: Reverse WD Power steering
    Posted: 02 May 2010 at 10:28am
Newbie looking for info on converting a WD narrow front to PS. Its a reverse WD loader, has crank-driven pump for loader. I can get some parts from a combine PS system, that used cylinders to steer, but can i just use a regular orbit motor to drive the steering shaft where the cylinders would plumb in, or different type of motor? Is there a better place to ask this question? thanks
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 10:43am
I have the same loader set-up with a crank driven pump on a WC. When I bought it there was a Char-Lynn in-line power steering set-up, it's about 3" in diameter and 10" long. The shaft going to the front end was shortened and this unit put in there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote posse_99 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 10:51am
Thanks, do you have any pics available? is it just the inline unit, like a power assist? just supply and return to the pump and reservoir?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 11:22am
When When I bought the loader the narrow front pedestal was junk and when I replaced it I didn't put the power back in. I'm going to use it this way and see how I like it. Here's a pic of the unit with the 2 hoses.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 11:24am
Forgot to say it is an in-line assist from the pump to reservoir.
Post Options Post Options   Thanks (0) Thanks(0)   Quote posse_99 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 1:50pm
thanks! Is this a factory setup or aftermarket?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 1:56pm
It's aftermarket. My loader was reversed by a company in Morris MN about 30 years ago, they added the pump, reservoir and steering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 10:05pm
On the YT classifieds there is a Char-Lynn power steering set-up for a WD/WD45 that is belt drive off the generator for $350 in Garden City MN.
