Return line?
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Topic: Return line?
    Posted: 19 Feb 2010 at 5:22pm
on a 190 is one of the settling bulbs a return line or they both for fuel flow. and if they are for flow where does the return line enter into the tank. someone before me had jerry riged a mess on this tractor before i got it. any help is appreciated.
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2010 at 7:09pm
Both shopuld be for flow, return should enter tank at bottom right front, when in back of tractor lookin at it, Im kinda sure!!!
Cowboy UP
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2010 at 7:10pm
Both shopuld be for flow, return should enter tank at bottom right front, when in back of tractor lookin at it, Im kinda sure!!! without double checkin mine
Cowboy UP
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2010 at 11:17pm
thanks for the help ill check it out. they pinched they left line off if looking from rear of tractor. and then run the return back into the flow line. tractor was running rough i think this might be the problem.
This page was generated in 0.227 seconds.
