Retrieved This Today: |
Codger
Topic: Retrieved This Today:Posted: 25 Mar 2026 at 12:09am |
Ran a couple hundred miles this morning to grab this auction purchase. Wll set it onto a 2015 Chevy pickup converting to a service truck. Will be so much more useful than the existing pickup bed. This bed and crane has very little usage and is extremely clean so should serve well.
That's All Folks!
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4945 |
Posted: 25 Mar 2026 at 5:40am |
that’s a nice bed!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25308 |
Posted: 25 Mar 2026 at 6:28am |
curious. what does the unit weigh ??
Codger
Posted: 25 Mar 2026 at 6:54am |
No idea to actual weight but I wouldn't think more than 3500# from the way it pulled on the trailer. I'll know later today when I pick it off with the gantry as I have a dynomometer, (crane scale) for the purpose. Will probably need to slip a leaf into the right rear spring pack along with longer "U" bolts to support the crane unit. Bed is Knapheid and crane is a Stellar which are both good names. I'm told was only in service about a year when something catastrophic happened to the truck.
That's All Folks!
Codger
Posted: 25 Mar 2026 at 12:38pm |
Cell phone camera only works when it wants yet gives the appearance of normalcy for a spell. Pictures revert to an unsupported format so new phone time, (again).
Bed is so heavy with that crane it was actually lifting the tubes just off the left frame rail of the chassis cantilevering on the right rail. I clamped it down with eight welding clamps so it won't go anyplace till I'm ready for the conversion.
That's All Folks!
Codger
Posted: 25 Mar 2026 at 4:56pm |
Memory card seems to have died in phone. Found an extra at home and seems to work well again though ultimately too small of capacity.
Crane dynomometer: ![]() Going to need a bed stretcher as it seems a bit short. ![]() Tubes used to set bed onto/span frame are shown here: ![]() ![]() Manual stiff leg jack for support: ![]() Lot easier to move around setting on this chassis till ready to convert the pickup next week at the earliest. Ordering lamps and hardware to mount this down to the receiving chassis later this evening. Haven't looked at anything electrical yet so no idea what is in store there. Probably beyond my wildest comprehension...... Should be a nice setup once completed. |
That's All Folks!
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4079 |
Posted: 25 Mar 2026 at 6:57pm |
what model b is that? does it still hve a five and four
Codger
Posted: 25 Mar 2026 at 7:28pm |
1957 B-61T. 5&3. I've owned since 4/79 and purchased from original owner. Engine is original and never apart except routine maintenance. Still have original rear suspension and rear axle but rerailed the truck and installed a Rockwell SQHP rear rear on Pete "Air Leaf". Rides much better.
That's All Folks!
Joined: 11 Sep 2009 Location: illinois Points: 91060 |
Posted: 25 Mar 2026 at 7:55pm |
do we need outriggers ?
Codger
Posted: 25 Mar 2026 at 7:58pm |
Not with a stiff leg and corner mount crane. That stiff leg is actually a smallerized semi trailer landing gear. They work well and I've installed several but mostly convert to hydraulic operation.
Bed is actually going onto a 2015 3500 Silverado pickup replacing the pickup box that is rusting out. They need another service truck and a pickup box really doesn't serve too well in the operation. I set it onto my Mack so it can be moved easily till the other truck is ready for the conversion. Edited by Codger - 25 Mar 2026 at 8:05pm |
That's All Folks!
Posted: 25 Mar 2026 at 8:15pm |
saw the photo of STIFF LEG, but not sure how that works... BOOM just swings over one side or back of truck ?
Codger
Posted: 25 Mar 2026 at 8:33pm |
It is a weldment to the back DOT type bumper in the rear. Mounts on the extreme end of the support. I've seen several types supplied with cranes but haven't worked with this one at all. I'll be out there tomorrow and look at it. It was cut off the frame stubs of the original chassis and set on the bed. I assume that crane is 360 degree rotation but do not know that either.
That's All Folks!
HudCo
Posted: 25 Mar 2026 at 10:08pm |
nice crane i drove the same year b 61 back in the 80s the one i drove had air steering , basicly a air cylinder on the drag link
Codger
Posted: 25 Mar 2026 at 10:19pm |
I have a 64 B-61ST, (tandem) with "Air-O-Matic" power steering. Also have a 74 RL-797LST with the same. Not a bad system but will deplete air quickly when jockeying around a parking lot, or positioning. I have a hydraulic setup for the single axle truck, (Garrison) but need to rebuild it as out of service many years. Always liked the look of those old trucks and this one is part of the family.
That's All Folks!
Codger
Posted: 22 hours 20 minutes ago at 7:32am |
Popped original bed and B&W hitch from the receiving truck yesterday morning. Looks like going to be an easy install later in the week. Original coating on the frame is peeling away from the age so while much is exposed, the young helper is going to come to the shop and do some steam cleaning action to remove this original coating and we'll apply another product that holds up well.
Bed lifted clear of the frame: ![]() Chassis out in the drive: ![]() ![]() They have located a dually rear axle I have yet to retrieve and install. Should be a nice package once complete. I pulled the bed to measure up and fabricate a materials list for mountings and weldments to attach to. They are going to sell the original bed including the bed, B&W hitch, patch panels for the wheel arches, and rear bumper for $1500. The rear camera in the tailgate works well also and the bed is not bent up at all; just rusted over the wheel arches. |
That's All Folks!
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1613 |
Posted: 10 hours 1 minutes ago at 7:51pm |
Seems like a little too much for that little Chevy!! Better suited for the Mack! But should be okay once you make it a dually.
Codger
Posted: 7 hours 55 minutes ago at 9:57pm |
That Chevy actually does pretty well with a load on the gooseneck trailer. Have hauled an 8070, (FWA, duals with fluid) several times with it. Though underpowered for that type work, it really handles and stops well.
That's All Folks!
