Resurfacing flywheel
Doobletango View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Topic: Resurfacing flywheel
    Posted: 30 Jul 2020 at 7:48pm
Hey guys, I’ve got the engine out of my D17 series 1 for some engine work. While it’s out I’m going to replace the clutch. I’ve heard of having to resurface the flywheel. What am I looking for to know if I need to have the flywheel resurfaced?
Rusty Allis View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rusty Allis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 7:59pm
in my opinion, it's SOP with a clutch job unless you like to do things twice. I suppose you could hit it with some 80 grit to break the glaze if you had no chatter issues
Bret (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 7:52am
Resurface for sure.  Whatever is removed from the clutch surface must also be removed from the surface the pressure plate bolts to.  There is a published dimension for that in the service manual that I don't have access to right now.  Maybe others can look it up.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 8:16am
Just had my D 15 flywheel turned . Had quite a wear ridge on it .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 9:06am
On the D15 flywheel, if you turned very much off, your clutch will feel limp. Make sure that the clutch and pressure plate are correct. Can't go by most manuals on this one. Most disc are much thicker than originals and cause pressure plate fingers to be too low. With the flywheel turned very much, you won't get needed travel to release pressure. Rick Corder can fix you up with correct clutch and pressure plate. If you notice lots of D14 and D15 tractors have a piece welded to clutch pedal rod, this was because of improper installation. A little wear on clutch then would cause throwout bearing to contact fingers and cause more wear and slippage. HTH Tracy
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 9:24am
Haven't found a company yet that will warranty their clutch if you didn't resurface the flywheel. One even questioned if it was turned on a lathe or ground on a flywheel grinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 11:24am
Thanks Tracy . My clutch and pressure plate are on the way to Rick . He told me the flywheel should always be turned . Maybe I should've measured the wear ridge ?
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 12:58pm
Is this true even if redoing the clutch on say a WD45?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 1:08pm
Always resurface when replacing the clutch. Asking for problems if you don’t.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 1:15pm
If it had not been turned and you faced of minimal amount you will be OK. Rick knows his stuff on these. He can get the new clutch disc and pressure plate fingers the correct height. If it were me, I would put an organic disc in it. You can feather the tractor easier aint near as hard on the flywheel. JMHO, Tracy
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 1:26pm
ACinSC...Doesn't make any difference on the flat flywheels about the wear ridge...just the recessed flywheels. What's taken from the face of the recessed flywheel, has to also be taken off the top flange where the pressure plate bolts down.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 1:28pm
And, yes...ALWAYS resurface the flywheel when doing a clutch job, to save you the headache later! LOL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 2:54pm
Thanks Rick . Makes sense to me .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 8:40pm
What’s the best way to get in touch with Rick? I can post my phone number if I need to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 8:54pm
PM him if you don’t have his number
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 9:03pm
Thanks!
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 6:47am
Randy...I sent you a PM in regards to the clutch and flywheel...Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 6:59am
Just for the record, lengthening the clutch pedal rod on ANY D14-15-17-19 does nothing but reposition the clutch pedal itself. It does NOTHING for helping release the clutch better/sooner. The throwout brg only has so much travel and it is limited inside the bellhousing.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 11:12am
Absolutely correct! Thanks, Dr. Allis for mentioning that. I have had a lot of folks that don't understand that, no matter how much you try to explain it.  :)  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 12:52pm
Exactly, that is why the height of the clutch fingers need to be set correctly. The pivot point of the fork could have been at a better location to allow for more travel of throw out bearing, with less travel of the foot clutch rod. This is why if the flywheel has been turned much  ,there is not sufficient travel to release clutch and have proper clearance from fingers to throw out bearing.Very little use and fingers are rubbing bearing! Tracy
