Restored d17 project |
Page <1 234 |
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 986 |
Found that line with a part number of 70228425.
Than looking at the long line going to the back has job weld patches… That one has a part number of 70229059 |
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3069 |
If you can't find a new or used one, you can make one.
I made a lot of new ones for my WD45. You may need to use a little different fittings than original but no one will notice. You could probably go to about any mechanic that does brakes too and have him make and flare you one. |
Are they a double flange? I’m not very good with steel line…
I have All States Ag Parts looking for them and they found the long one but was having trouble finding the short one I think it’s was. Maybe Heitman Tractor Salvage would have them? I seen they had a lot of d17s listed on their website. Got to looking at the long one and the other guy tried to jb weld it… Wonder how long that would’ve lasted.. |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8641 |
Inverted flare. A quality tool should form that fine.
What kind of material is best?
How thick? I’m pretty sure the original is steel… Edited by 55allis - 11 Sep 2025 at 12:37am |
Use Brake line
All states ag found some good used ones for me!!
I tried some local shops around and they told me they have never seen that big of brake line before… Got them yesterday and put them on, no hydraulic leaks!!! ![]() Had to order front wheel bearings due to one being rusted pretty badly and the other worn out very severely. Should be in tomorrow sometime. I think this project is getting wrapped up now thanks a’ll for the patience and help!!!, |
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3927 |
Is an interesting thread. Thanks for sharing
Gatz in NE ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1061 |
like others, I suspect the cam/crank timing; especially since all 8 pushrods are bent.
What's with the grease on top of the pistons ? If the engine had run at all, that grease would've been burned up in a short time, or fouled the plugs.
Page <1 234 |
