Restored d17 project
 Post Reply Post Reply Page  <123
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 11:06am
Not necessarily. But if the cam timing to the crank was off, it probably wouldn't ever run regardless of where the ignition timing was. Late camshaft timing would result in the exhaust valves getting smacked when the piston was coming up and the exhaust valves aren't yet closed.  This catastrophic failure of the valve train can only be from incorrect valve guide height. The cam/crank timing was correct. How could 8 valves be stuck in their guides?? very doubtful.
Les Kerf View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 11:11am
Originally posted by 55allis 55allis wrote:
I was meaning if the cam time was off the distributor could be off too…
With the head off you can easily verify the cam timing without a degree wheel simply by putting the #1 piston at TDC, then look at the cam lobes. At the tail end of the exhaust stroke both lobes will be upward with the overlap split because the exhaust will be just closing and the intake will be just beginning to open.
If the cam timing is off enough to matter then it will be obvious to the naked eye.
This is probably not where the problem lies with this engine, but it is so easy to check that it is worth doing just so that you know it is correct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 12:37pm
If the guides and caps aren't interfering and cam timing looks correct and guides weren't stuck about all that's left is rocker adjustment. So wait a minute...tall heads use short stands,short heads use tall stands...do we have short head short stands?
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 9:31am
Does anyone have any pictures comparing the two?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 9:39am
Here is a picture before I removed it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 10:00am
I wonder if he had the rocker arm stands upside down ?? Long side goes down to the cyl head.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 12:55pm
In that picture it looks like #4 intake is the only valve that is closed. I wasn't aware of two different pedestal heights that SteveM mentioned, but I was able to find a picture on Facebook of a D17 engine, and it looks like the pedestal mounts are about 1/2" taller. It also looks like there is a color change on the studs about 1/2" above the nuts in your picture, like maybe that is where the nuts used to be. I learn something new every day.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 8:09pm
I believe that would do it Dead
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 8:39pm
Yea looks like the rockers are just about up against tray.
How strong are the rockers after that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 9:54pm
Here’s a picture of the rocker currently…
I never changed anything from when I pulled it off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 11:05am
I can't tell from pic. Is head about 4in thick? Should be on a 17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 11:11pm
Originally posted by TedN TedN wrote:
... I wasn't aware of two different pedestal heights that SteveM mentioned, but I was able to find a picture on Facebook of a D17 engine, and it looks like the pedestal mounts are about 1/2" taller...
The only thing I have heard about regarding two different pedestal heights involves the early WD heads vs the later WD and the WD45 head; i.e. the 'Short' head and the 'Tall' head, which requires different pedestals.
According to three different online advertisements selling rocker pedestals for the D17 they measure 1.945" tall.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 12:38am
Not sure how to do links but I was able to download the picture. Maybe I'm wrong, but it looks different to me. Keep in mind I don't have much familiarity with D17s, I am only going by what I see in the pictures.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 6:51am
Ok guys,
 I am on the edge of my seat (ok the couch) and the popcorn is almost gone! I need Dr Allis to tell me a little more about valve guide placement. No I am not a engine builder. No I know nothing about valve guides. (I have a machine shop do the head work on any engines I am working on which is not very many) But it sounds like if the guides are incorrectly installed this stops the valve movement and then can bend the pushrods on the other end of the rocker? I am a little confused but I am old and easily confused too.
Humm This is like a who dunit murder mystery. Let's all take a trip to 55 Allis land stand around drink coffee or beer and noodle and lay hands on this awesome restoration.
Sorry for being sarcastic on the restoration thing. I do a little work every couple years on my own stuff. I make many mistakes. But I do not call any of these old tractor projects "restorations"! That word is for folks that have way more skills than I have. But I must say I was not impressed with the very first exterior picture of this finished restore D17. Sorry maybe my expectations are too high. And yes shiny paint does not mean it will run. I understand that. But if a customer is going to pay good money for 7 years of fiddling the details should be slightly better inside and out. Just my rambling 2 cents. Not trying to step on anyone's toes here. I hope this tractor can be completed for the owner and that they get many years of enjoyment with it. Makes me want to find the old D17 and fire it up!
Chris and Cheryl
I just started another batch of popcorn.
I like the wrong head or wrong rocker arm combo idea for some reason? :) Maybe the butler did it!
I also wish Don Bradley was able to chime in on this engine situation too. RIP Don!
Just thought of another one for the team! Could the push rods have been purposely pre bent so that they made the valve train look like it functioned. Ok that idea is stranger than aliens building the pyramids!
Edited by Sugarmaker - 27 Aug 2025 at 6:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 8:28am
Valve guides do not appear to have been replaced…
But they don’t seem to be even
Plan is to go ahead and rebuild the head, going to local engine shop tomorrow....
It would be interesting to know what the rebuilder has to say about the guides
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 12:42pm
Talked to the shop who has the head and he hasn’t looked at it yet…
Said he’d try to look at it today or tomorrow.
The valve guides look original, rust is still on the bottom side. So I don’t think it would be that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 2:33pm
... :) Maybe the butler did it!...
I'm beginning to think that way myself Tongue Reckon maybe it was Col. Mustard? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 11:27am
It’s been a week now and I’m still waiting on the head…
He did give me an update and found the seats was ground to a 30 degree instead of a 45 degree… so he’s going to grind them again to correct them.
Would that be enough to stick the valves? And bend the push rods?
Onto the rear crank seal: it does appear to have been replaced BUT in the process it appears he turned a wrench too much and cracked the top seal retainer.
What material is that made of? Is it weldable?
It feels like aluminum but it could be cast aluminum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 11:34am
Intake valves on any D-17 head are 30 degrees. Exhaust are 45 degrees.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 11:55am
Called him and he figured that out before he did anything.
Thank Doc
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 7:15am
There are lots of those crank seal holders around. Call Bill Deppe or Orange Knight(Lad Benes) and see if they have one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 11:55am
....and remember to GLUE felt in place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2025 at 10:05am
What kind of glue has worked best for you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2025 at 11:24pm
Well it’s now on the path to come together again!!
Got the rear crank seal put in and the fly wheel on, now I’m waiting on the clutch input seals to come in, maybe tomorrow afternoon mail and I need to pick up the head from the head shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 55 minutes ago at 11:36pm
Good news today!!!
Got it to spin over freely and no bending push rods!!
Starter spins it nicely, very good compression (finger test) it almost will suck my finger in the spark plug hole!!
So far no leaks on the seals I put in..
I think it will fire right up when I can get spark.
Gas line was completely plugged with crap so I had to blow air through it until it came out.
I adjusted the valves to .015 of an inch cold, so I think that should do until it warms up.
