resistor location on coil?
John In. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Topic: resistor location on coil?
    Posted: 28 May 2010 at 11:38pm
   Well, I went and done it..changed over to 12 volt.. got tired of replacing 6V batteries, I had a 12 V. genny but found out it was shot. Went to a delco alt. also changed to negative ground. The question I have here is the coil calls for a resistor..do you hook it up before or after the coil ?
                                       Thanks,   John
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 12:16am
   Before coil.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 6:02am
Electrically it doesn't really matter. It's parts of a series circuit.+12volts to switch to coil to resistor to points to ground is the same as +12 volts to switch to resistor to coil to points to ground. Physically it's easier and neater to wire it between the switch and the coil + wire. Electrons don't care...
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 7:21am
Just put a 3 ome coil on it ,then you need NO resistor
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 7:31am
John
The ballast resistor is sensitive to the elements. Install it in a place that protects it from the elements (inside the tool box?). When I convert a CA to 12 volt, I use a 12 volt Gennie (for the original look) and mount the VR inside the tool box to protect it from the elements and to maintain the original look. I also purchase a 12 volt internally resisted coil (not too expensive from your local auto parts store) instead of re-using the 6 volt coil and the ballast resistor for reliability reasons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 1:43pm
Go to Farm and Fleet and buy a new 12 volt coil and forget about the resistor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 7:35pm
 thanks guys, I do have a 12V genny but it was no good so I borrowed the Alt. from my Monti that I am restoring. I already had the coil and the paperwork said that I needed the resistor.   Thanks again    Jhon
