Rescuing an Allis B That Should Be Parts
BryceBurden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BryceBurden Quote  Post ReplyReply Direct Link To This Post Topic: Rescuing an Allis B That Should Be Parts
    Posted: 6 hours 9 minutes ago at 2:52pm
Hey everyone,
I figured it was time to start a proper build thread on this little Allis B I dragged home recently. I picked it up in an online auction last week, and to be totally honest… it’s probably the saddest tractor I’ve ever loaded on a trailer.
Most folks would have called it a parts tractor or yard art, and I wouldn’t have blamed them. But Bs are getting hard to find in my area, and when you do find one, it’s usually in about the same shape for three times the money. I’ve been told more than once that I’m crazy for trying to save this one – which usually means I’m on the right track.
My plan is to do a full teardown and rebuild, one subassembly at a time. The engine will probably be the last thing that gets rebuilt. First comes dismantling, transmission, final drives, steering gear, and so on. I’m documenting the whole process, and I’ll post updates here as I make progress. I’m always open to advice, tips, or warnings from folks who’ve been into these Bs before.
Here are a few photos from the day I brought it home:
For anyone interested in following along, I’m also making a video series on the rebuild. Here’s the first part of the project:
Appreciate any input from the Allis folks here, and I’m looking forward to sharing the journey as this little B slowly comes back to life.
— Bryce
Allis B Rebuild Part 1
Edited by BryceBurden - 6 hours 7 minutes ago at 2:54pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 6 minutes ago at 2:55pm
looks alot better than some of the stuff ive started with
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 38 minutes ago at 3:23pm
Roger Welsch is smiling down on you!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 45 minutes ago at 4:16pm
no battery... no boss mount for generator on engine ... front rims rivet to the hub.... your right.. its an early one... Serial number is on the trans casting by the shift lever... Motor casting "11" should be the second year of manufacturing i thinkg.. started with "10" ??  Might be an engine serial number on left side of engine casting by bell housing..
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 23 minutes ago at 4:38pm
Hi, what is the reason for the chain under the bell housing?
If you were closer, I have an engine with no freeze cracks id let go cheap
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote BryceBurden Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 9 minutes ago at 5:52pm
From what I can tell so far the front half going off the 11 casting code is a 39. The transmission and final drives are later, serial number shows to be a 48. In the video I stated the rear half was a 47, but that was before I realized that the serial number records on this site showed the last number for that year rather than the first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BryceBurden Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 6 minutes ago at 5:55pm
The chain under the bell housing is what is holding up the stay rod for the axle. The casting is broken off where it would normally attach to. Not sure how I’m going to fix that yet, have a lead I’m going to check out soon on a parts tractor with what I hope is a good block, but the torque tube has been broken in half on that one so that won’t do me any good in that department
