Repowered 720 Oil light coming on
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Topic: Repowered 720 Oil light coming on
    Posted: 18 Aug 2019 at 10:11am
My 720 has been repowered with a Kohler, 20hp engine.  After running for approximately 10 minutes or so the oil light comes on, don't hear any difference in the engine, if I shut it off and restart it, light goes out and will not come back on for another 5 to 10 minutes and the process can be repeated.  How does the sending unit function on these engines, does it sense oil level or what?
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2019 at 11:08am
Does your Kohler have an oil filter? That would indicate if it were splash lubed or full flow oiling. Either way I'd check for a loose wire on the sending unit or a bare spot on said wire.
Edited by exSW - 18 Aug 2019 at 11:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2019 at 11:47am
It has an oil filter.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2019 at 12:34pm
On my Magnum 18 the port for the oil sending unit is right above the filter.
Edited by exSW - 18 Aug 2019 at 12:35pm
