Replacing the cork on a WD45 crankshaft
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: Replacing the cork on a WD45 crankshaft
    Posted: 01 Mar 2026 at 3:08pm
I am sure I read on this forum about replacing the pilot bearing on a WD45 with a sealed bearing, removing the cork from the crankshaft and threading the end of the crankshaft and installing a threaded plug.
I have searched and I have had no luck finding anything. Does anyone have any experience doing this. What size plug should be used. Any tricks that I should know? Should the plug have (red) Loctite?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2026 at 9:06pm
WC? I thought that was over before 45's.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 5:35am
The WD45 used a wick in the end of the crank other than a handful of engines that used a cork.  Not sure what benefit you'd gain going to a sealed bearing.
AaronSEIA
This page was generated in 0.107 seconds.
