Replacing the cork on a WD45 crankshaft |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5180 |
Topic: Replacing the cork on a WD45 crankshaftPosted: 01 Mar 2026 at 3:08pm |
I am sure I read on this forum about replacing the pilot bearing on a WD45 with a sealed bearing, removing the cork from the crankshaft and threading the end of the crankshaft and installing a threaded plug.
I have searched and I have had no luck finding anything. Does anyone have any experience doing this. What size plug should be used. Any tricks that I should know? Should the plug have (red) Loctite? |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 01 Mar 2026 at 9:06pm |
WC? I thought that was over before 45's.
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 02 Mar 2026 at 5:35am |
The WD45 used a wick in the end of the crank other than a handful of engines that used a cork. Not sure what benefit you'd gain going to a sealed bearing. AaronSEIA
