replacing crankshaft pulley
54f250 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 54f250 Quote  Post ReplyReply Direct Link To This Post Topic: replacing crankshaft pulley
    Posted: 07 Jul 2025 at 1:25pm
I removed the crankshaft pulley (series II D12) in order to replace a leaking front main oil seal.  I broke it taking it off.  I have a new pulley but is at least as much trouble going on as it was coming off.  My crank od measures 1.12 as does the pulley id.  I know I have to heat it, but is there anything else I should be doing?
Also, Does the pulley side with the set screw go inside or outside the pulley? When I took the pulley off, the set screw was inside but if I put the new pulley on with the set screw in, the fan belt will not be aligned.
Any advice will be greatly appreciated.
jim
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2025 at 2:10pm
70236741 is before s # 3001  70235043 is after s # 3001 that is series II
This page was generated in 0.089 seconds.
