REPLACING CAB FLOOR |
SIMPLICITY
Joined: 19 Sep 2009 Location: ERATH LOUISIANA Points: 517 |
Topic: REPLACING CAB FLOORPosted: 04 Jun 2010 at 9:07pm |
HELLO
I AM LOOKING AT A BLACK BELLY 7060, THE FLOOR IS BAD, DIDN'T GET TO PULL THE FLOOR MAT UP COMPLETELY JUST PULLED IT UP AT THE DOOR. THE BOTTOM OF THE CAB AT THE DOOR IS RUSTED OUT. THERE IS A BAD SPOT AT THE END OF THE FENDER BY THE DOOR BACKWARDS FOR ABOUT 6" IS BAD. THE FRAME WORK UNDER THE FLOOR MAY BE BAD. HAS ANYONE CHANGED THE FRAME WORK OUT? IF SO DOES THE CAB NEED TO BE LIFTED TO CHANGE IT OUT. THE REPAIR TO THE CAB BOTTOM, HAS ANY ONE DONE IT? IF SO HOW MUCH TROUBLE AM I LOOKING AT? ANY TIPS. THANKS FOR THE HELP |
