Replacing auger drive belt on model 72 combine
N186364 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote N186364 Quote  Post ReplyReply Direct Link To This Post Topic: Replacing auger drive belt on model 72 combine
    Posted: 01 Apr 2020 at 7:22pm
The unloading auger drive belt on my model 72 combine needs to be replaced ( the parts book calls it : belt, unloading conveyor ). Does anyone have a good " how to " on this especially regarding how to get the new belt around the PTO drive shaft? Also does anyone know the size of the belt?
wlambs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wlambs Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 6:46am
HAVE TO UNBOLT THE PTO FRONT SLIDE BELT ON THEN THE BACK. ALLCROP HARVESTER HAS THEM TOM YAZZ
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 12:05pm
What he said.  Specifically part # 1 below:
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 7:22pm
I actually had to replace a leaky front oil seal on my gearbox and while I had the front drive shaft removed it was a perfect time to replace the auger belt. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote N186364 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 7:32pm
That's great. Thank you all. Tom, a picture says a thousand words. I'll take a run at this in a day or so. Do I have to worry about a torque value when I re-assemble the PTO shaft?
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 8:03pm
I have had instances like this where I put two belts on at the same This is mostly when the belts go bad quickly. I install one as is needed and tie the second out of the way until needed. I know that this belt does not get extensive use but just thought I'd throw it out there. Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote N186364 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 9:42pm
I did look at the " allcropharvester.com " web site and the auger belt is listed with a part number but also ( very helpfully ) the letter/number combo for this belt which is B61. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 3:13pm
NP.  Torgue?  Dont think so on the torque---I have never heard of such a requirement
