Replacement WD Sediment Bowl Sealant
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Topic: Replacement WD Sediment Bowl Sealant
    Posted: 10 Nov 2024 at 5:40pm
New experiment on the WD... Used some Gasolia pipe sealant on the new sediment bowl assembly (I used thread tape last time, which... yeah, didn't work great, of course). Supposedly rated for liquids including gasoline. Maybe now it will quit leaking out on me over winter.
Also cut down a small mesh screen to pop in the top of the stem so maybe I won't get so many random bits of bug debris in the tank. I got fragments of a wasp and a spider out after draining and filtering the gas!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2024 at 6:24pm
That is my go to for any threaded connections. If for water, then add teflon tape
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 7:46am
I used the yellow thread tape (gas/oil rated) last time I replaced a sediment bowl assembly, and it's held up for at least one year now.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 12:05pm
I used Permatex 80016 always keeps fittings of any kind from leaking,doesn't get hard so if the fitting needs to be moved a tad it still won't leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 8:40am
Yup! I'm wit' Gary on dat. That Permatex 80016 is the best! Coarse, a lot of Permatex products are great.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 4:10pm
plummerscarin -- Whew, glad to hear I'm not the first to try it!
wjohn -- Also thought about that option but wasn't sure if the tape worked well with that style fitting.
Gary / Steve -- Hmmm didn't think about gas safe form a gasket, that may be something for next time.
