Replacement cutting edge
framerman61 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote framerman61 Quote  Post ReplyReply Direct Link To This Post Topic: Replacement cutting edge
    Posted: 02 Jan 2015 at 9:58pm
where can you find replacement cutting edge with the correct hole patterns. I need cutting edge and end bits for a AC 653 with 6-way blade
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2015 at 5:14am
Try Stephens Equipment, near Pittsburgh, PA.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2015 at 12:54pm
a lot of the things are standard punching - end bits might be more of a problem , should be some heavy equipment people in your area you can check their books .
This page was generated in 0.250 seconds.
