Repair B Front Spindles
Foolster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foolster Quote  Post ReplyReply Direct Link To This Post Topic: Repair B Front Spindles
    Posted: 21 Feb 2012 at 8:24pm
I have a 1944 B with worn front spindles. Both spindles are badly worn where the bushings are both top and bottom.
Is there an easy cheap fix to this?
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2012 at 8:27pm
new bushings are available. sometimes the spindals are wore real bad too and need work. not horribly expensive if you can do most of the labor yourself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2012 at 8:45pm
If the spindles are wore, chuck em up between centers in a lathe and turn them down to at least1/8 U/S. weld them up and recut to original size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foolster Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2012 at 8:52pm
The actual spindle is worn to a smaller diameter where both bushings are. Can I double up on the bushings by putting new bushings in the spindle housing and a second set of bushings on the spindle then tap everything back together and have it work? The spindle that turns inside the axle hub is worn down both top and bottom about the thickness of a bushing. I am thinking of using a grinder to square off the worn areas on the spindle so the spindle looks like it was machined to take a top and bottom bushing on the spindle.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 7:13am
 I have a pair of spindles that aren't worn much at all if you're interested.  $20 each + flat rate box USPS shipping.  N-series Ford bushings (P/N 2N3109 I believe) are a very economical replacement at less than $3 each.  They are slightly longer than the originals, but this gives you more bearing area.
Edited by BrettPhillips - 22 Feb 2012 at 7:15am
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 8:02am
Brett
    Are the spindles you have for sale for the arched axle or the adjustable axle?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 8:26am
The worn spindle shafts are probably no where near round any more and the best way but not the cheapest way is to build the low areas up with weld and turn them back to new bearing ID specs in a lathe.
And.  Hope the axle housing was  not worn to badly after half the bearings went away.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 12:04pm
The spindles that I have are for the non adjustable arched front axle.  Sorry I wasn't specific.  If you want to fix what you have, CTucker and Ken have the right method.  The worst part about these spindles is that area where the steering arm mounts is the same diameter as the wear area, so you can't turn them undersize and make custom bushings.
cwc39 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwc39 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2012 at 8:57pm
Let me know whether or not you still have the WD front spindles, and where you are so I can price shipping. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2012 at 9:20pm
The spindles that I had were for a B, but they are sadly long gone. As fate would have it, I needed a pair of them about a month after they were sold!  Moral:  Don't sell NOTHIN"!
