Removing gearbox pulley 7 mower |
Post Reply |
dr p
Orange Level Joined: 24 Feb 2019 Location: new york Points: 1008 |
Posted: 23 Sep 2021 at 5:21pm |
I had a seal start leaking so I thought it would replace it before I put the mower away for the season. To get at it need to remove the driven pulley. I am a little confused on how to get it off. There is an "L" shaped key that meshes the pulley to the shaft. Do I need to remove that key first or can I take a gear puller and pull the pulley. (I do realize that pulley has been on there for 60 years and it may require some friendly convincing. Thanks for any input.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77615 |
some keys have an L on the end to keep them from falling thru or falling off during install.. Key should not stop you from pulling the pulley off. A puller with 2-3 arms that goes thru the pulley holes and grabs the hub is best.. Then screw against the end of the shaft... Sometimes heating the pulley hub with a propane torch can help... And of course, Penetrant is your friend !.
MACK
If has a L on the end, it is tapered and will tighter as you try pulling pulley. Drive pulley in will loosen key. I would rather eat glass as try to remove that type. MACK
DonDittmar
Orange Level Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2476 |
. I agree. Anything on a taper is usually a PIA to deal with
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2851 |
If you are a purist about things being original then replace the seal,if not and just want to use the mower then fill the gearbox with JD corn head grease and your problem will be solved.
Boss Man
Orange Level Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 608 |
L shaped keys are a night mare. Unless its a major leak leave it alone and use corn head grease
dr p
more a patience of job than a strength of samson task but i got it. as always, thanks for the good advice
Post Reply | |
