Removing 271 engine
WaltDevore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Topic: Removing 271 engine
    Posted: 20 May 2021 at 10:30pm
the torrential rain is abating and winter winding down.  Time for another big go at ressurrecting the old HD5.  Made decent progress preparing to pull the engine. Only question now is what to do with hydraulic pump.  Does one unhook the hydraulic lines and the pump comes out with the engine, or,  leave hydraulic lines attached and remove hydraulic pump to hang down below engine?  Not obvious to me and the manual makes no mention. Thanks for your guidance.
Edited by WaltDevore - 20 May 2021 at 10:31pm
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2021 at 10:48pm
You can leave the pump in and remove bolts from engine mount and lever it forward to clear engine , as it uses a coupling and plate mounted in front pulley on crank .
