Removed from pickup bed
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Removed from pickup bed
    Posted: 31 Jan 2025 at 1:51pm
the gooseneck hitch. This was in our new to us F-350.
Two iron channels that were bolted down crossways in the bed, with a big plate that has the ball hitch, was just sitting down in the two channels. I could lift the plate out, it was just sitting in those channels under its own weight. I take that not correct? What is supposed to hold this plate in the channels?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 5:09pm
PHOTO please.
These are what I had in my F250 prior to bed removal, the smaller angle iron parts are now attached to the hitch box on my new flatbed.
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 5:25pm
There should be 4 hitch pins with hairpin keepers, one for each “corner” of the top plate, that slide in (front to back) through the lugs of the top plate that drop down into the channels, securing the plate into the channels.
A fifth wheel will mount the same way if you want to use one
Edited by RedHeeler79 - 31 Jan 2025 at 5:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 6:32pm
Don’t have a gooseneck, or a fifth wheel trailer at this time, just a bumper pull recreational trailer, and a tow dolly.
Just went to the storage shed and checked, it appears to be ‘Curt’ brand.
I’ve never figured out how to post pic’s on this site using my iPhone, this site I only access also only from my iPhone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 6:40pm
What is that hitch in the picture rated for? I always over build everything- its gotta be bolted to the frame - a few welds - I do understand that if the load it right, theres not that much pull on the ball - but being on I 44 ALOT , seeing some pretty crazy weight distribution thats bad
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 6:50pm
Not sure, I just found an image to illustrate my explanation of the pins and keepers. Those channels bolt through the bed floor, and connect to angle iron brackets that are bolted through the frame directly under the bed / channels. (Typically). This setup is made to convert a fifth wheel rail mount to a gooseneck ball. I’d assume the standard gooseneck mount (under the bed) is stronger, but i have seen the rail mounted plate style with a 25k lb rating. (Curt brand Spider mount)
Edited by RedHeeler79 - 31 Jan 2025 at 6:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 6:55pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 8:39pm
Lars
The picture of the Curt 5th Wheel Hitch that L'il Stevie posted is only part of the Hitch.
The two channels that you mentioned are in the Bed of your F-350 and bolted to Angle Brackets located below the Bed and bolted to the Truck Frame.
If you look at RedHeelers picture, you will note how the 5th Wheel Plate is fastened to the 2 Cross Channels with 4 Hitch Pins and Keepers.
That style of Goose Neck / 5th Wheel Hitch was totally redesigned around the 2020 Model Year Pick-up Truck.
The Optional Goose Neck / 5th Wheel Prep Package only includes the 4 special corner Angle Brackets and a Centre located Goose Ball Bracket.
This new design lets a customer easily relocate this New Design from his used Trade-In Truck to his New Truck without any Tools etc.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 9:57pm
Thanks for everyone, the pic Steve put up is exactly what I have.
Gary, you are correct, mine were bolted down thru the truck bed to angle brackets that I have left attached to the truck frame, just in case I ever need to reinstall this hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 10:11pm
POOO TDS Gareee............. everyone knows the ANGLES are bolted thru the bed to the frame... the QUESTION was how does the plate attach.. RED answered that and Doug asked WHAT IS THE RATING for that hitch............... Trry to keep up with the discussion..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 9:16am
These same Hitch mounts as I had in my F250 were what BILs neighbor had bolted into his Short Bed GM, FAILED to install the To Frame Angles, bed cracked to bupkus, he still tried to drag a fifth wheel to CO from Fenton MO, trailer tore hitch off truck and ended up flipping both.  WHATEVER move this to, always inspect the bed to frame angles and boltings reasonably often.  Mine were all that were holding the OEM 8 footer to my Ford when started that project.
I left those angles on my frame and when installed Flatbed made them into anchors at Hitch Box.
Edited by DMiller - 01 Feb 2025 at 9:20am
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 3:17pm
Posted: 16 hours 58 minutes ago at 11:11pm
Posted: 5 hours 53 minutes ago at 10:16am
POOO L'il 'thinks he knows it all' Stevie
Your Buddie DMiller kinda blew that misinformation out of the water.
AND ENDED UP FLIPPING BOTH - TRUCK AND TRAILER!
g
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 4:05pm
WTF is wrong with you  TDS Gareee..... ?????????? The channels IN THE BED are bolted thru the bed... and to the frame rails... NOT  JUST THE BOTTOM OF THE BED !! ...It is not one 12 inch long bolt !! . See DAVES PHOTO
Still knit picking a word here or there ?... Did you check my spellin ??
Edited by steve(ill) - 01 Feb 2025 at 4:08pm
ekjdm14 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 6:55am
Now now ladies Tongue
(but do carry on by all means, I need a smile after seeing the state of the wheel rim I have to rebuild!)
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 8:47am
Steve did you leave that g off on purpose?
Post Options Post Options   Thanks (2) Thanks(2)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 4:10pm
LOL  Clap .... I gots to give them something to SNIVEL about !
This page was generated in 0.106 seconds.
