Remove spool valve, AC-185
Allis_Cooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis_Cooper Quote  Post ReplyReply Direct Link To This Post Topic: Remove spool valve, AC-185
    Posted: 12 Nov 2024 at 1:21pm
I have decided that the valve assembly on my AC-185 is leaking out of the front and rear seals on the spool valve that controls the main lift. (I am assuming that there is a nylon seal at the front and rear of the spool). Thanks to this forum I got the parts, AGCO part # 70255229.
My question now is, can I pull that spool out without taking the valve assembly off the tractor?   Will it make a big mess?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 6:57pm
Yes and a little.  With the spool in hold - mid position. Pull the back cap - 2 allen head capscrews that hold the aluminum rear cap on and the e clip and pin on the front of the spool - then CAREFULLY remove from the rear. DO NOT mess with the detent spools. IF it is leaking on the center spool oring - take it to someone who has done it before.
