Remove A/C clutch
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Remove A/C clutch
    Posted: 12 Sep 2022 at 5:54pm
What’s the best way to remove the clutch from the compressor? Old fashioned square-ish compressor, 1995 3406. Clutch fell off, have another complete unit, but not the equipment to evacuate the system. Figure I would swap clutch. How can I hold the clutch and unscrew the center bolt at the same time?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2022 at 7:41pm
A/C clutch tool...duh
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2022 at 8:05pm
 Hey Lars,,,having had to "DO OVERS" enough times when I tried to "save" a little money and time by NOT evacuating system,, I NOW always evacuate the system, especially in the hotter months due to excess humidity and that is what you trying to get out. I don't think Oriellys has the vaccum pumps but they do have the clutch puller tool tho. Good Luck!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2022 at 9:04pm
Thanks guys, I haven’t ever seen a clutch puller tool, guess I’ll have to do a search
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2022 at 4:35am
Getting the bolt out should not be that tough, just have to hold the remnant of the drive plate to break loose and unscrew. That drive plate IIRC is threaded for a 5/8 USS bolt to push it off the taper shaft.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2022 at 8:13am
Big ass channel locks
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2022 at 9:29am
Or the Bigazz brand of channel locks
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
This page was generated in 2.518 seconds.
