remote propane tank gauges
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Topic: remote propane tank gauges
    Posted: 28 Jan 2026 at 2:02pm
Any experience with them? Recommendation? Have a 500 gal LP tank at a house quite a few miles away. No internet connection there other than cell phone. I own the tank; Dad bought it long ago. I believe year of manufacture is 1985 or earlier, so obviously the gauge is not WIFI compatible or having any type of external wiring. I'd like to set it up with an external remote sensor/gauge I could read from my phone.
Thanks
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 3:44pm
You might check with your fuel supplier, they would probably know of the most up to date products out there otherwise have the driver put you on their route and then when they are in the area they just top your tank off and one less thing you have to think about. That’s how we work with our supplier and when he hears there is a price increase in the works he gets to us before the increase or if the price is headed down he waits for that as well. We have been with the same company for over 50 years and have always been treated well
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 4:01pm
I have never ued one, but this sounds like a possibility... Might talk directly to them..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:28pm
Thanks for the replies. I did see that one on Amazon. This tank does not have remote ready R3 dial.
   The propane services I've dealt with charge extra if the tank is not below 20 percent. Local term is a "Short load" and they tack on a much higher delivery fee.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 32 minutes ago at 7:33am
I've dealt with a lot of LP fuel suppliers throughout the midwest over the years when working. Citing you own the tank you are not limited to whom the fuel is purchased from. Most vendors I have dealt with had a minimum 100, or 150 gallon drop, and then there were no delivery charges. I didn't utilize vendors that did not have this option.
I used Hicks, Ferrel, FS, and several small "Mom & Pop" suppliers over the years for fuels and don't remember ever paying a delivery fee.
Remote monitoring is a good feature to have. Used it for years but it was hard wired.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 43 minutes ago at 8:22am
Our home tank only supplies Range Cooktop and two grill connections, average refill every two years is 75-85 gal in a 125g Horizontal tank.  Have considered a whole house 10-14kw LP Generator where would change that to at least a 500g tank, then replace the small tank we own altogether.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 50 minutes ago at 10:15am
I buried a 1000gl tank at the shop to be rid of the above ground tank. It is nice and out of sight except a slight riser above grade for filling, and service porting. To ensure the tank stayed below grade I poured  runners formed with 2X12 lumber with screw in earth anchors 24" deep and 5/8" rebar welded to the anchor tops which is centered, and encased in a monolithic pour of concrete. I had also welded threaded studs to the rebar which protrude through holes in the storage tank legs and are fastened down with stainless washers and nylock nuts. The anchorage points are then encased with an electrical potting compound which is waterproof.
Basically any ground hydraulic pressure attempting to push this tank up will be against the two six foot runners and three screw in anchors in each runner at the same time.
That's All Folks!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 11 minutes ago at 10:54am
Hey Steve-
This is a multifacet challenge, which means a multi-facet solution.
Yes, propane distributors already do this kind of thing, but they generally don't do it for the CUSTOMER, they do it for THEMSELVES.  They do it basically to automate the demand collection/monitoring process for 'keep full' contracts, and usually it's on tanks THEY own.  they use a for-purpose tank reader sensor that clips over the top of the tank's regular 'swing needle' indicator... but one must recognize how that needle works...
The needle isn't physically connected to any mechanism THROUGH the tank... the tank is a high-pressure vessel, and doing so would place the gauge in situation of being a rupture or leak point, so rather, that needle is usually just a magnetic compass.  The float level mechanism is connected to a rotating shaft that ends just UNDER that needle, and has a magnet bar on it.  The needle you see, matches the position of the magnetic bar beneath...
...as long as the needle isn't sticky from being 300yrs old... and the magnets are still good...
In the case of MY tanks, about half of 'em have a piece of steel sitting on top, whose function is to serve as a whacker... when I go to LOOK at the gauges, I tap on 'em with the whacker a couple times to 'wake up' the needle, which will swing to a 'more suggestive' suggestor of content level...
Now, the 'clip on sensor' thingies the supply company uses, consist of a fluxgate sensor that measures the magnetic field under that needle (directly from the magnet inside, right?), and once it figures out what the angle is, it converts it to digital data, and sends it over what is usually a cellphone-like data connection.  The propane supplier pays a fee for a low-volume data connection for each tank, and they integrate all those readings into their management software to figure out when they'll send more your way.
Now, I own my tanks, and I have MY contracts set up for 'will call' delivery.  I never wind up placing a 'small' order, so don't worry about 'short loads'... but I DO like to see what my fuel levels are without trudging through three feet of snow in high wind, and my gauges are always sticky, So I use a more reliable method:
I weigh my tanks.
So your question has several steps for the answer:  First of all, distance...
You're far from the tanks, and don't want to go there (like me, snow, and wind, just... farther.
but distance isn't the whole story... and it's not necessarily a problem... vector and obstruction is an important part... CAN YOU ESTABLISH A SIGHT-LINE betwixt the two points?
IF you have a pole, a tall building, a hillside, or some other situation at each end, that can establish a line-of-sight, then you can use ordinary off-the-shelf wifi routers (especially older, obsolete units) with a removable antenna, set to 'BRIDGE' mode, will provide a data connection from one to the other.  IF you're in a situation where there's no utilty power available, a rechargable battery pack (or old lead-acid car battery) with a solar charger will do.    You'll need a pair of directional antennas pointing towards eachother, and some suitable feedline (RF cabling) to connect the antennas to the routers.
Now... the INFORMATION...
build a pallet or platform to place under the tank.  Install two load cells (strain gauges.. like single-ended shear-beam 2k capacity) to mount on one side of the pallet, and two support feet on the other.  Half the weight of the tank will thence be borne atop the load cells.
Connect the load cells' excitation and signal wires together, into an inexpensive scale indicator.  Use one that has a network connection, which you'll set to some static address that works in conjunction with your bridges and your home network.
Get a scale-tech friend to help get the initial calibration of the tank scale set up, and at some point, get the tank down to about 20% to get a good zero capture.  Then fill the tank, use the fill receipt to calculate the filled weight (in a 1000gal tank, 80% from 20% is 600gal, so for a 500gal that's 300...) at propane's 4.24lbs/gal, you'll be around 4.24*300=1260lbs.
Set up the scale indicator to stream those weights.  Find a code-kid to write a little program that'll display those weights on an HTML page (many scale indicators can include text strings inot the weights stream that can act as HTML, so a web browser will actually just show it like a web page).
If your code-kid is really good, he can whip up a little script that'll take regular readings of your tank, put it in a spreadsheet, and make it so you can see how fast you're using how much propane over a given timeframe.
Edited by DaveKamp - 11 hours 60 minutes ago at 11:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 45 minutes ago at 6:20pm
In order of replies: Yep, I get why they charge extra for a "short load". They have the same mileage, driver costs, etc in a small load as a full one and obviously you don't make as much money per gallon, so you charge accordingly. Plus you have to plan your routes and how much at each tank, so its crucial to know the numbers you are working with. That's why the first question they ask when I call is "How much in the tank/what percent??"
I can spend $100 in gasoline to go check that gauge, so I'm looking for ways to avoid both costs. I've averaged it over 10 winters and from that data I'm using between 0.3 and 0.5 percent per day on a normal year; completely winterized and set at 40 deg. However 14 consecutive days of single digit and below 0 nights has me thinking it's using a lot more than the average. Just like everyone else north of the Florida Keys. If the wireless gauges work well then it would be handy to look at an app on my phone and know for sure without bothering the neighbor "Hey can you trudge through a foot of snow and call me?"
      Dave, as always you impress me with the detail of your answers. I was wondering how the gauge works and that explains it. I did not think of magnetism. I assumed it was a heavily sealed float with some kind of an isolator system so that it would hold against pressure. The site is on a hill. It gets good cell service and I have multiple wireless trail cameras that work flawlessly. I have two son-in-laws that are mechanical engineers. I'll see if they want to try the weight system.
Thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 3 minutes ago at 8:02pm
Steve.. i know nothing of this... but wonder if it is POSSIBLE to install the R3 gauge you talk about on an Old Tank so you could use the NEW monitor ???
