Remanufacturing Allis Parts
 Post Reply Post Reply Page  <1234>
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 6:13pm
I guess I forgot about them being slid under the hood that far. A tractor one could still be made to work I would think with a little modification to the front of the tank.
acdeerboy123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdeerboy123 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 6:21pm
  have a set of good used fenders for earley d-10 e-mail me at  mlux@netins.net for more info
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 7:02pm
Affordable lift arm latches.
Doyle B(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 7:11pm
any thing on an allis chalmers 5040. tough to find parts
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 7:23pm
  give some dimensions tie rods are not that hard to find  read my post back the way
  wehave ps gears hein warner pump gears [hyd. pump  a-c 241776 shafts  read my web site or call 1-574-342-4545 ca help  on any if your wallet is big enough  they like paid too  my 2 cents
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 8:03pm
I made up some Barnes PS Pump shafts a few years ago, and had no takers when I offered them here, so I only finished one for myself.  Fred is right, very few parts are really worth what it will cost to make them, even at minimum wage.  I hate to say it, but tractor folks are cheapskates...
Bryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 8:09pm
How about some buda 273 engine blocks. Seams like every body is looking for those blocks.  That covers both AC and cockshutt guys.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 8:36pm
Ross steering gear parts, B,C,CA,D10,D12.
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 9:23pm
Definitely fuel tanks fro pre "D" series models.  Thanks!
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 10:13pm
D series fenders to original dimensions and gauge.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 6:21am
How about D17 series I and II power steering pumps for this cheapskate tractor owner?
Wink
I am a Russian Bot
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:31am
Items requested that we have looked into or already have.
1. D14,D15 Fenders  Had quote done $28,000 per die x 2 = 56,000 x L & R $112.000
2. IB frame,  Have them.
3. D10 Hood, Have sample in and getting them made.
4. D Series, Have them in stock seat cushion as origional, Pan slight different to save on die.
5. D17 & D19 Fenders, Have. As Tony stated not bad for the money.
6. D Series Headlight mounts and grab handle. Have in stock. Had them cast.
7  Tach drive adapters D series off dist housing, Have in stock.
8. Lift arm latched. Have them being made. CA, D10,D12
These are parts that have been requested and have aquired or am working on and will add to our inventory as we can. David
734-320-3470
THANKS
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 8:50am
734-320-3470
THANKS
Dave,
I see you have new(I assume they are new)  WORKING Traction booster guages....Whats the story on getting those made?  Are they of the same construction or based on a typical modernday hydraulic pressure gauge?
Edited by TomYaz - 25 May 2011 at 8:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 10:49am
All new gauge, Modern Hydraulic tenchnology I hope. sold 10 so far with no complaints.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 12:47pm
The IB beams are being made by http://www.kammerer-inc.com/
Bill B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 8:14am
After the hassel i have had i think D-17 diesel radiators should be added to this list.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 8:51am
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 8:54am
L 15-25 fan screen
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 8:56am
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 9:17am
Well Dick, I guess that is one way to clean out your gas tank.
1968 D15D,1962 D19D
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 9:26am
I've been thinking about trying to make the bottom circular part of the rib for the fender  for the D- 10, 12, 14, 15.
Dusty
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 10:30am
Dick,
How do you put it back together?
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 10:57am
TIG weld.
I spot welded a locating band to hold the edges straight.
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 11:31am
Originally posted by Coke-in-MN Coke-in-MN wrote:
Seems there is also a large industry now springing up in far east reproducing old motorcycle parts for British motorcycles.  Seen a NOS gas tank for Matchless cycle sell for $950 and a NOS  Norton tank go for $1200 , you can now buy reproductions of those tanks for $240 and $285 in chrome plated form.
 Might pay for someone to see what these companies would charge to reproduce a tractor gas tank or fender. I know couple of the outfits are looking for pattern tanks to copy for other models so they can duplicate.
 Unsure if there are more tractor restorers or old motorcycle restorers out there .
I just bought a front disc brake rotor for Norton for $97 , made in India, as the ones said to be NOS from England are $350 and the so called good one i bought on E-bay for $40 turned out to be a worn out piece from a scrap pile behind someones shop.
I've heard that those Norton tanks don't even hold gas (from India).  I thought about getting one for my Combat to replace the original fiberglass one.
What kind of Norton do you have?  Mine is a '72 Commando 750 Combat that is metallic gold colored.
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 11:37am
I would second the 5000 series.  Particularly the engine parts, as these are totatly unavailable and quite a few good machines are scrapped cause rings, valves,  and valve guides are not available.  The rest is somewhat available from AGCO, I have gotten several parts from them for my 5015, but hte motor parts don't exist in their stock.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 12:14pm
Wide front for WD45, a snow bucket for the trip loader would be nice lmao. Hydraulic cylinders, hydraulic lines for wd45, lift arm latches
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 12:16pm
Originally posted by Dick L Dick L wrote:
TIG weld.
What did you use to take it apart? The edges where you took it apart look like they're straight from the stamping dies...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 12:45pm
Saber saw and angle grinder. Two different tanks. One had the bottom rusted out bad and the other one was bashed in across the top. Probly a tree or someone had a real bad temper. Both were junk to smart people. But I just hada had em.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 6:48am
I am in the process of rebuilding fenders for my D-17. One thing I could use , is if someone would just make the back bracing that spot welds onto the fender. On one fender I have cut two in half to make one. It is finished all but some filler to hide the weld area.   Dave.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 7:41am
I have a dozen or more  B/C/CA tanks with issues like dents and rust. I keep trying to talk myself into making 1 out of 2 like Mr DickLs example shows it can be done.
 No real need to reproduce anything but the tank bottoms in most cases.
 Is there a way to cut one solid tank in two to knock out dents and tig it back together. I can see why using 2 would work better because there is no way to split the seam.
     Reproduction C allis fenders would make a C allis restorers day.
