Remanufacturing Allis Parts |
Page 123 4> |
BrianC ![]() Orange Level Access ![]() Joined: 16 Jun 2011 Location: New York Points: 1619 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Sep 2011 at 8:15pm |
Big need for B/C/CA type gas tanks.
And C specific fenders. |
thomas davison ![]() Bronze Level ![]() Joined: 28 Apr 2011 Points: 27 |
It may be possible that some dies, etc are stored by AGCO in a salt mine somewhere in Kansas. I do not know how you can find out. They may have been destroyed by now.
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5092 |
Don't offer them money. Tellem to take it off the broken baby bottles bill they threw on the floor when you had to carry them every where. (:^D
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Thanks Dick I see. I see. When you do it it looks easy.
I have two grown boys that are expert welders. They take jobs from everybody and anybody but me. They act like my money is no good.
I deeded both of them 7 acres to build on so it's not like they need gas money to drive down to my shop.
Now, if it was my wifes tractor that needed a gas tank they would be fightin over who gets the job.
Easy, Just cut the bottom or bottoms below the seam, spot weld a band like in my picture to hold the edges flush with the inside of the top and weld below the seam. After welding make sure you use a tank liner kit while the inside is still sanded clean. That will take care of any pin holes in your weld if you happen to get any. The band around the inside gives you a thicker metal to weld which will helps with keeping from burning thru.
I have a dozen or more B/C/CA tanks with issues like dents and rust. I keep trying to talk myself into making 1 out of 2 like Mr DickLs example shows it can be done. No real need to reproduce anything but the tank bottoms in most cases.
Is there a way to cut one solid tank in two to knock out dents and tig it back together. I can see why using 2 would work better because there is no way to split the seam.
Reproduction C allis fenders would make a C allis restorers day.
David Maddux ![]() Orange Level ![]() Joined: 13 Sep 2009 Points: 2543 |
I am in the process of rebuilding fenders for my D-17. One thing I could use , is if someone would just make the back bracing that spot welds onto the fender. On one fender I have cut two in half to make one. It is finished all but some filler to hide the weld area. Dave.
Saber saw and angle grinder. Two different tanks. One had the bottom rusted out bad and the other one was bashed in across the top. Probly a tree or someone had a real bad temper. Both were junk to smart people. But I just hada had em.
AC WD45 ![]() Orange Level ![]() ![]() Joined: 28 Sep 2009 Location: Mid Michigan Points: 2063 |
Wide front for WD45, a snow bucket for the trip loader would be nice lmao. Hydraulic cylinders, hydraulic lines for wd45, lift arm latches
German Shepherd dad
Reindeer ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Calgary, AB Points: 650 |
I would second the 5000 series. Particularly the engine parts, as these are totatly unavailable and quite a few good machines are scrapped cause rings, valves, and valve guides are not available. The rest is somewhat available from AGCO, I have gotten several parts from them for my 5015, but hte motor parts don't exist in their stock.
aras ![]() Orange Level ![]() Joined: 28 Jul 2011 Location: Weston, WI Points: 665 |
I've heard that those Norton tanks don't even hold gas (from India). I thought about getting one for my Combat to replace the original fiberglass one. What kind of Norton do you have? Mine is a '72 Commando 750 Combat that is metallic gold colored.
TIG weld.
I spot welded a locating band to hold the edges straight.
GlenninPA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Dick,
How do you put it back together?
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
I've been thinking about trying to make the bottom circular part of the rib for the fender for the D- 10, 12, 14, 15.
Dusty
DonDittmar ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2516 |
Well Dick, I guess that is one way to clean out your gas tank.
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
L 15-25 fan screen
Doyle B(NY) ![]() Silver Level ![]() ![]() Joined: 20 May 2011 Location: New York Points: 150 |
After the hassel i have had i think D-17 diesel radiators should be added to this list.
wbecker ![]() Orange Level ![]() ![]() Joined: 29 Oct 2009 Location: STL Points: 837 |
The IB beams are being made by http://www.kammerer-inc.com/
Bill B
David(Stockbridge)MI ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: Stockbridge MI Points: 536 |
All new gauge, Modern Hydraulic tenchnology I hope. sold 10 so far with no complaints.
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler |
TomYaz ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: PA Points: 10340 |
Dave,
I see you have new(I assume they are new) WORKING Traction booster guages....Whats the story on getting those made? Are they of the same construction or based on a typical modernday hydraulic pressure gauge? Edited by TomYaz - 25 May 2011 at 8:51am |
Items requested that we have looked into or already have.
1. D14,D15 Fenders Had quote done $28,000 per die x 2 = 56,000 x L & R $112.000
2. IB frame, Have them.
3. D10 Hood, Have sample in and getting them made.
4. D Series, Have them in stock seat cushion as origional, Pan slight different to save on die.
5. D17 & D19 Fenders, Have. As Tony stated not bad for the money.
6. D Series Headlight mounts and grab handle. Have in stock. Had them cast.
7 Tach drive adapters D series off dist housing, Have in stock.
8. Lift arm latched. Have them being made. CA, D10,D12
These are parts that have been requested and have aquired or am working on and will add to our inventory as we can. David
734-320-3470
THANKS
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
How about D17 series I and II power steering pumps for this cheapskate tractor owner?
Wink I am a Russian Bot |
WD45 ![]() Orange Level ![]() ![]() Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 957 |
D series fenders to original dimensions and gauge.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
EPALLIS ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 1161 |
Definitely fuel tanks fro pre "D" series models. Thanks!
Ross steering gear parts, B,C,CA,D10,D12.
Bryan ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 463 |
How about some buda 273 engine blocks. Seams like every body is looking for those blocks. That covers both AC and cockshutt guys.
BrettPhillips ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Strasburg, VA Points: 808 |
I made up some Barnes PS Pump shafts a few years ago, and had no takers when I offered them here, so I only finished one for myself. Fred is right, very few parts are really worth what it will cost to make them, even at minimum wage. I hate to say it, but tractor folks are cheapskates...
Page 123 4> |
